Empty Linuxcnc Stand Alone working template file
12 Feb 2018 20:47 - 12 Feb 2018 22:15 #105800
by Grotius
Empty Linuxcnc Stand Alone working template file was created by Grotius
For those who want to make a stand alone application with linuxcnc.
Here is a empty project that you can copy and run.
There is also a readme file included, where to place the different project files.
After you got this working, you can add some code from different sources.
I would copy an paste code examples from the earlear uploads in this thread or search for other examples.
Good luck !!
This picture is nice :
Okey to get widgets working you can add in the python code :
from gmoccapy import widgets
self.widgets = widgets.Widgets(self.builder)
If you make led's and button's it will work. example code for button :
Good luck !!
def on_emergency_stop_pressed(self, widget, data=None):
self.command.state(self.cnc.STATE_ESTOP)
#self.command.state(self.cnc.STATE_OFF)
self.widgets.led_emergency_stop.set_active(False)
#self.widgets.led_machine_on.set_active(False)
print " E-stop pressed, safety stop, power off, drives enable "
def on_machine_on_pressed(self, widget, data=None):
self.command.state(self.cnc.STATE_ESTOP_RESET)
self.command.state(self.cnc.STATE_ON)
self.widgets.led_emergency_stop.set_active(True)
self.widgets.led_machine_on.set_active(True)
print " E-stop reset and machine is on "
Last edit: 12 Feb 2018 22:15 by Grotius.
Time to create page: 0.075 seconds
