Python interface states of the home switches?
24 Jun 2019 13:38 #137736
by pl7i92
Replied by pl7i92 on topic Python interface states of the home switches?
spindle means world wide differencet in many languageses it is a tread
like SFU2005 or Tr12x3
Rod is right you become very fast into the system im in since oktober 2018
and now as on the 60th mashine build you become very fast to errors
the first errors on new freshmen and system change 10.04 /Lcnc2.5 to 2.7.14 and now to 2.9 stretch is quite fast solution
i need to Quote as on Plasmac and or qtpyvcp panes im not getting any error at all widgets can not load
or tcl missling
as of rod and phils advice i will wait to convert the shop plasmas (now 5 Mashines) till the master is up and there is a iso that makes all itself
gnipsel install fails as of germany depencies not retchabel and tcl not to be installed
or tcl missling
24 Jun 2019 23:59 #137761
Now I know why my surname means Weaver! Its all about the spindle!
Replied by rodw on topic Python interface states of the home switches?
Whats a spindle for instance!
Here you go: spindle. The definition of a spindle is a thin rod used for spinning, or a yarn measurement. An example of a spindle is what sewing thread is spun around. An example of a spindle is 15,120 yards of cotton yarn.
26 Jun 2019 02:54 #137853
by lorenzn
Replied by lorenzn on topic Python interface states of the home switches?
Looking for an equivalent to (parameter value):
setp edge.scope.10.in-edge 0
I don't see a corresponding hal.set_value(). hal.set_p() operates only on pins. For now I'll use subprocess:
edge = '{}.{}'.format(edgename, pincount)
if inedge == 'rising':
subprocess.call('halcmd setp {}.in-edge 0'.format(edge), shell=True)
#hal.set_p('{}.in-edge', '0') #fails only for pins
else:
subprocess.call('halcmd setp {}.in-edge 1'.format(edge), shell=True)
26 Jun 2019 03:22 #137855
Replied by cmorley on topic Python interface states of the home switches?
looks like your code is wrong.
try:
Chris M
try:
hal.set_p('{}.in-edge'.format(edge), '0')
Chris M
26 Jun 2019 03:31 #137857
by lorenzn
ah so it does work with parameters. Thanks once again for handing me the solution on a platter!
Time to create page: 0.146 seconds
