How to custom UI location?
24 Apr 2018 11:11 #109539
by emptyhb
How to custom UI location? was created by emptyhb
I'm start learning how to create gui for Linuxcnc with glade and python.
First i want to put all python file of UI in one folder, but i dont now how to config Linuxcnc load UI from that folder and relative python file in there?
01 May 2018 22:22 #109960
Replied by andypugh on topic How to custom UI location?
When loading a GUI via the INI file (and that's the commonest way to do it in LinuxCNC) then all paths are relative to where the INI file is.
31 May 2018 20:04 #111362
Replied by cmorley on topic How to custom UI location?
Might I suggest you use gscreen to load your UI and gscreen handler file to write your python code.
linuxcnc.org/docs/2.7/html/gui/gscreen.html
It's not super well documented but does give some basic examples in the docs.
I might add that the sample screens of gscreen's are mostly all development vehicles - they don;t always show the easiest way of doing things ( as it was a learning process).
It's easy to start with just a GLADE ui file and have gscreen display it by naming it tester (see the docs)
for instance gscreen will give you these variables for config location:
self.data.CONFIGPATH - folder from the launched configuration
self.data.SKINPATH - folder from of the avaliable skins
self.data.BASE -the base location of linuxcnc (this changes if you use RIP vrs installed )
I'm willing to add more docs of gscreen based on questions I get - gscreen's purpose is to facilitate custom screens.
If you are dead set on doing things yourself then I suggest you look at gscreen or gmoccapy code as they both can be used as example code of how to do things for GUI display.
Chris M
Chris M
The following user(s) said Thank You: emptyhb
Time to create page: 0.168 seconds
