Custom gui with glade
- echesortux
- Topic Author
19 Jun 2018 12:00 #112577
by echesortux
Custom gui with glade was created by echesortux
Hello everybody, I am trying to design a custom interface using glade and following the guide wrote by John Thornton but I am having problems with Glade. I am using Glade 3.8.0 it is built-in in linuxcnc ISO (I am using lastest version of linuxcnc).
when I try to add a HAL_gremlin plus componenet to whatever object (top window, tab, etc) Glade crash I can see this error in the console
"(glade-3:4086): Gtk-WARNING **: Attempting to add a widget with type GtkHBox to a HAL_GremlinPlus, but as a GtkBin subclass a HAL_GremlinPlus can only contain one widget at a time; it already contains a widget of type GtkAlignment
Gtk:ERROR:/build/buildd-gtk+2.0_2.24.10-2-i386-Tg7Q_2/gtk+2.0-2.24.10/gtk/gtkwidget.c:5130:gtk_widget_reparent_fixup_child: assertion failed: (client_data != NULL)"
am I doing something wrong? is there other way to create an interface?
Thanks.
Thanks.
19 Jun 2018 15:42 #112581
Replied by cmorley on topic Custom gui with glade
Which iso are you using?
which version of linuxcnc?
Chris M
Chris M
19 Jun 2018 15:49 #112582
I confirm this error on the debian stretch iso. (glade version 3.8.0)
i also use Mint which I installed glade version 3.8.6 and it does not crash.
I'd suggest not using gremlinplus widget unless you can update the GLADE version.
IIRC version Glade 3.8.0 was buggy.
Chris M
Chris M
The following user(s) said Thank You: echesortux
- echesortux
- Topic Author
19 Jun 2018 18:16 #112594
by echesortux
Replied by echesortux on topic Custom gui with glade
I am using linuxcnc 2.7.13
regading iso I downloaded from the link of the oficial linuxcnc web
www.linuxcnc.org/linuxcnc-2.7-wheezy.iso
- echesortux
- Topic Author
19 Jun 2018 18:54 #112595
by echesortux
I just compliled glade 3.8.6 and it seems to be working ok at least it doesn't crash when I add a gremlinplus object. I will continue with John tutorial.
Thanks you cmorley.
Thanks you cmorley.
20 Jun 2018 04:06 #112606
Glad you got it going.
I wanted to add - If you are building a screen for linuxcnc with gladevcp widgets, there is a program that was intended to help with that - Gscreen.
linuxcnc.org/docs/2.7/html/gui/gscreen.h..._sheet_custom_screen
Chris M
Chris M
- echesortux
- Topic Author
20 Jun 2018 20:55 #112659
by echesortux
thanks I will take a look at it. it seems very good.
Time to create page: 0.214 seconds
