Custom Gui keyboard key press
- echesortux
- Topic Author
06 Jul 2018 12:49 #113566
by echesortux
Custom Gui keyboard key press was created by echesortux
Hello everybody, I am making a custon gui using glade and python so far so good, the problem is that I want define some function such as "open file" using a key stroke instead using the mouse in my custon Gui. I have read that is posible using "key press event" but I don't figure out how to use it with a widget.
someone could please help me?
06 Jul 2018 15:47 - 06 Jul 2018 15:48 #113576
Replied by cmorley on topic Custom Gui keyboard key press
Are you using GTK2 (like gladevcp)?
Look at Gscreen or Gmoccapy both of these offer keystroke functions.
If you allow jogging with keys - it's a pain in the ass to get it right.
For gscreen the initialize_keybinding binds the events from the main window to the on_key_event and the on_key_event pre-process the key events and sends that to a lookup function that calls a 'do something function'
gscreen keybindings are complex because it allow customization.
basically the function between thw try/except in on_key_event is where you would put code to pick a key code and do what you want.
googling ' pygtk on_key_press' probably would get some useful hits too.
Hope that helps
Chris M
Hope that helps
Chris M
Last edit: 06 Jul 2018 15:48 by cmorley.
The following user(s) said Thank You: echesortux
- echesortux
- Topic Author
06 Jul 2018 16:54 #113587
by echesortux
Replied by echesortux on topic Custom Gui keyboard key press
Thank Chris, I am trying to make a GUI from scratch. no using other existing interface. In fact I want to it for a press brake so the idea is to create a panel using switch and avoid using keyboard and mouse. I know that for more of the function I can use halui (In fact I will use it to power on, run, homming, etc)but my problem is how to load an ngc file without using keyboard and mouse so I though that maybe if I can create key then I could simulate this key press. May there is a better way to do it.
Thanks.
Thanks.
06 Jul 2018 23:25 #113615
Well Gscreen was made for building custom screen but some people like to code there own from scratch and that is fine
Norbert built a icon based file loading widget (iconview) maybe you can adapt it to use real buttons rather then a touch screen.
Chris M
Chris M
Time to create page: 0.117 seconds
