QtVCP Style Sheet Editor
20 Mar 2019 05:30 #129040
by phillc54
QtVCP Style Sheet Editor was created by phillc54
I have declared a style sheet that exists in my config directory by the following in the initialized function of my handler file:It works perfectly well.
I am attempting to use the Style Sheet Editor, so in the __init__ function of my handler file I have:But it seems to require that the stylesheet has the same name as the UI file and be in a specific directory as I get the following error:
Is there a way around this?
Cheers, Phill.
self.w.setStyleSheet(open('any_old_name.qss').read())
self.STYLEEDITOR = SSE(widgets,paths)
OSError: [Errno 2] No such file or directory: '/home/phill/git_imac/lcnc/share/qtvcp/screens/plasmac_ui'
Cheers, Phill.
20 Mar 2019 06:24 #129042
Replied by cmorley on topic QtVCP Style Sheet Editor
Yes if you name the qss file the same as the ui file (but with the qss ending) and place it in the screen folder, it will load it automatically.
But it should be possible to load and save a qss file anywhere from the editor.
I will try to see whats going on...
Do you get the error on starting the screen or when starting the editor?
Chris M
Chris M
20 Mar 2019 06:44 #129043
by phillc54
Replied by phillc54 on topic QtVCP Style Sheet Editor
When starting the screen.
Cheers, Phill.
Cheers, Phill.
20 Mar 2019 09:02 #129046
ok pushed some work on that - shouldn't error now.
Please let me know if there are other needed improvements for the editor.
Chris
Chris
20 Mar 2019 09:17 - 20 Mar 2019 09:30 #129047
by phillc54
I get the following error popup:and the following in the terminal:
That is with self.STYLEEDITOR = SSE(widgets,paths) either active or commented out in the __init__ function.
Cheers, Phill.
EDIT:
I reverted commit 6cdbc93 and I can run the screen with STYLEEDITOR commented out.
File "/home/phill/git_imac/lcnc/bin/qtvcp", line 434, in <module>
APP = QTVCP()
File "/home/phill/git_imac/lcnc/bin/qtvcp", line 353, in __init__
window.apply_styles()
File "/home/phill/git_imac/lcnc/lib/python/qtvcp/qt_makegui.py", line 123, in apply_styles
if self.PATHS.QSS is not None:
AttributeError: Paths instance has no attribute 'QSS'
Cheers, Phill.
EDIT:
Last edit: 20 Mar 2019 09:30 by phillc54.
20 Mar 2019 18:08 #129088
did you make after pulling in the changes? i changed something in qtvcp that requires a remake.
Chris
Chris
20 Mar 2019 23:07 - 21 Mar 2019 00:16 #129122
by phillc54
OOPS, that fixed it.
Thanks Chris.
Cheers, Phill.
EDIT:
There is a small typo in the title bar, H should be lower case.
It would be nice it it used the same save dialog as the gcode editor.
I like the way you can apply the style immediately, definitely a time saver.
Thanks Chris.
Cheers, Phill.
EDIT:
Last edit: 21 Mar 2019 00:16 by phillc54.
Time to create page: 0.090 seconds
