Qtvcp use with grinder
12 Jun 2019 08:21 #136703
by partec
Replied by partec on topic Qtvcp use with grinder
this was also my suspicion but that will be ok soon I think, thank you Chris
Peter
Peter
12 Jun 2019 11:00 #136710
by pl7i92
Replied by pl7i92 on topic Qtvcp use with grinder
im also struggeling to get qtpyvcp on 2.9 debian9
cant get vtk on the system pip will not install it and vtk6 is not what to be needed to qtpyvcp
this is different to qtvcp
lots of name confusing
12 Jun 2019 16:20 #136753
Replied by andypugh on topic Qtvcp use with grinder
If you are embedding in Touchy then the details of this commit might be interesting:
github.com/LinuxCNC/linuxcnc/commit/1bcd...1f714346de50bc5b6c55
It allows the embedded code in the custom tab to know that it is currently active.
13 Jun 2019 05:04 #136806
Replied by cmorley on topic Qtvcp use with grinder
So I found a debian Stretch version on my laptop.
I added linuxcnc's buildbot's master version of linuxcnc.
I already had qt5 designer on the computer (and it worked with the RIP version of linuxcnc)
i did the file links/coping by starting a sudo filemanger in a terminal with the command:
sudo thunar
The installed qtvcp library is in:
/usr/lib/python2.7/dist-packages/qtvcp/plugins/
I made a link for qtvcp_plugin.py by clicking the file and selecting the dropdown 'edit' and then selecting 'make link'
that leaves a link file called 'link to qtvcp_plugin.py'
I moved that file to:
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/
If the /python part is not there then you would need to add it first
I then started designer in a terminal with the command:
designer -qt=5
The widgets showed up.
Chris M
sudo thunar
designer -qt=5
Chris M
13 Jun 2019 05:13 #136808
I can confirm you can also put this link into:
~/.designer/plugins/python/
(for anyone jumping in I skip the part about copping libpyqt5_py2.so file - see the docs)
Chris M
Chris M
Chris M
14 Jun 2019 15:53 - 14 Jun 2019 17:32 #136892
by partec
with new DVD 4.9.0-9-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.168-1+deb9u2 (2019-05-13) x86_64 GNU/Linux
step by step install but no success with LinuxCNC widgets
Last edit: 14 Jun 2019 17:32 by partec.
14 Jun 2019 21:27 #136914
'is package python-pyqt5.qtsvg installed'
please install this package and try designer again.
Chris M
Chris M
14 Jun 2019 21:53 #136920
by partec
eruepe@vre:~$ sudo apt-get install python-pyqt5.qtsvg
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Die folgenden NEUEN Pakete werden installiert:
python-pyqt5.qtsvg
0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 31.2 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 124 kB Plattenplatz zusätzlich benutzt.
Holen:1 ftp.ch.debian.org/debian stretch/main amd64 python-pyqt5.qtsvg amd64 5.7+dfsg-5 [31.2 kB]
Es wurden 31.2 kB in 0 s geholt (178 kB/s).
Vormals nicht ausgewähltes Paket python-pyqt5.qtsvg wird gewählt.
(Lese Datenbank ... 172574 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../python-pyqt5.qtsvg_5.7+dfsg-5_amd64.deb ...
Entpacken von python-pyqt5.qtsvg (5.7+dfsg-5) ...
python-pyqt5.qtsvg (5.7+dfsg-5) wird eingerichtet ...
eruepe@vre:~$
very easy Chris, thank you so much, result is great! We can try to go on now, it is wonderfull, thank you all for this things!
python-pyqt5.qtsvg
eruepe@vre:~$
15 Jun 2019 05:42 #136953
I take it you see the widgets in designer now - excellent!
If you want audio alerts and the camera alignment widget to work, you need to add these libraries too (other error messages in your post):
[QTvcp.QTVCP.LIB.AUDIO_PLAYER][[33mWARNING[0m] no audio alerts available - Is gstreamer-1.0-tools installed? (audio_player.py:39)
[QTvcp.QTVCP.WIDGETS.CAMVIEW_WIDGET][[31mERROR[0m] Qtvcp Error with camview - is python-opencv installed? (camview_widget.py:41)
Let me know how you experience building a screen goes - it's all very new code!
Chris M
Chris M
15 Jun 2019 08:00 - 15 Jun 2019 08:07 #136962
by partec
just tried CamPY setup for use on my favorite laboratory CNC
in stretch environments there is always something like
~/linuxcnc/configs/CamPY$ sudo python CamPY_setup.py
File "CamPY_setup.py", line 23, in <module>
import apt
ImportError: No module named apt
now I'm jumping to try
python-opencv is installed now but
gstreamer-1.0-tools was not found
but "Cam View" works already perfect in QTvcp-Screen-qt_cnc
import apt
Last edit: 15 Jun 2019 08:07 by partec.
Time to create page: 0.263 seconds
