GScreen docs
10 Jun 2019 14:14 #136474
by Reinhard
GScreen docs was created by Reinhard
I failed on the very first sample of custom screen with gscreen. As soon as I try to add an action as described, the designer crashes. Designer is the recommended version 3.8.6
Now I realized by accident, that the linuxcnc-actions have a contextmenueoption "add as toplevel widget", which works fine.
May be its worth to update the docs
cheers Reinhard
cheers Reinhard
10 Jun 2019 15:35 #136480
by pl7i92
Replied by pl7i92 on topic GScreen docs
thank you for your bug fix
will you share your gscreen or only a small change from a previous
10 Jun 2019 19:49 #136510
Replied by cmorley on topic GScreen docs
Thank you - I will add that to the docs. Unfortunately that version of GLADE is pretty buggy and won't ever be fixed.
Chris M
Chris M
11 Jun 2019 03:06 - 11 Jun 2019 03:12 #136534
by Reinhard
As I worked with mach4 before, I wanted to use Qt, but I don't get it working. Qt works, but not with linuxcnc widgets.
So I tried glade. Glade is rough and clumsy but after all, I got something similar to what I wanted.
So next step is use glade with linuxcnc extensions.
All tutorials failed. The one from gscreen was the first i got to work by accident.
So gscreen seems to be the only way viable ...
There's so much I have to learn and understand ...
My goal is usability - not fine grained polishing
//edit:
Don't know, whether it may be useful
I attach the error output from glade designer from the crash when trying to attach a halaction to an empty window
Replied by Reinhard on topic GScreen docs
Any advice, which version I should prefer?Unfortunately that version of GLADE is pretty buggy and won't ever be fixed.
I'm at the very beginning. Nothing to share yet.will you share your gscreen or only a small change from a previous
//edit:
Last edit: 11 Jun 2019 03:12 by Reinhard.
11 Jun 2019 06:13 #136556
That version is probably the best. Save your work often.
GLADE doesn't support it anymore - We are using old libraries because linuxcnc is currently stuck with python 2.
Hopefully i can get QT fixexec on install versions soon.
Chris M
Chris M
Time to create page: 0.071 seconds
