Send a email when the machining is end
31 Jul 2019 09:54 #140990
by julien83
Send a email when the machining is end was created by julien83
Hello, I would like send a email when the machining is end.
have you a method for that.
thanks
thanks
- Dinuka_Shehan
- Thank you received: 26
31 Jul 2019 10:13 #140993
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Send a email when the machining is end
Please,don't post multiple threads!
Merci
Merci
31 Jul 2019 10:55 #140996
Replied by rodw on topic Send a email when the machining is end
There would probably be a python library that sends emails. Good Luck!
31 Jul 2019 17:58 #141019
by Hakan
Replied by Hakan on topic Send a email when the machining is end
You can do a user-defined M-function, in where you do something likeInsert the call to the M function on a good place at the end of your g-code program.
#!/bin/bash
echo "Machining finished" | mail user@hotmail.com
- Thank you received: 5946
31 Jul 2019 18:23 #141023
Replied by tommylight on topic Send a email when the machining is end
Most probably you will need an e-mail server for that, or you can use POP3 or IMAP from gmail or yahoo mail.
01 Aug 2019 06:35 - 01 Aug 2019 06:43 #141073
by Hakan
Either set up the computer to be a good citizen in the e-mail world (some work)
or use a mail gateway.Here is an example of that
unix.stackexchange.com/questions/363814/...and-line-using-gmail
I won't give an example. I have been doing such stuff years ago, but lost it and it is now done differently.
Last edit: 01 Aug 2019 06:43 by Hakan. Reason: Forgot things
Time to create page: 0.505 seconds
