linuxcncrsh
22 Aug 2019 12:53 #142838
by Be9
linuxcncrsh was created by Be9
In linuxcncrsh, I set set_wait to done and expect to get a reply when the actual position reaches the commanded position.. 80% of the time, that is what happens. 20% of the time, the reply comes early. Isn't this what set_wait done means? If not, what should I be doing to get this behavior? I have loops to check the actual position before continuing, but this is slow and ridiculous. I am communicating with the ruby socket gem over a wireless connection.
22 Aug 2019 13:45 #142846
by pl7i92
Replied by pl7i92 on topic linuxcncrsh
hi if you get a look at the Styro/Foam option stop/wait at corner you may find a solution
you also need to set G61 at the programm start so it moves realy to the commanded postition then the function triggers perfect
you can monitor halui distance to go
and halui at command end
also a AND2 that monitors programm running and motion in position can give you a option
