USB haas operator panel interface
19 Feb 2021 12:05 - 19 Feb 2021 12:26 #199407
by fupeama
Hi Chris,
its great, now it looks like program. not like dump of numbers and letters in my "program"
I used stm ide because I didnt know about arduino ide with stm support in time when I wrote it.
I like STM IDE that you can use an online debugger to look inside the program and on the variables.
I think this code will benefit many people.
Martin
Replied by fupeama on topic USB haas operator panel interface
It seems it is a complete example but was for teensy? micro.
i am trying to adapt it to the stm32.
I found the STM IDE too complicated to attempt this - I there is a lot of moving parts to get right just to start to program it.
Using the Arduino with STM would be a lower bar for people to experiment.
Hi Chris,
Martin
Last edit: 19 Feb 2021 12:26 by fupeama.
20 Feb 2021 17:08 #199545
by fupeama
Hi Chris,
have you any idea how to control vfd? which pin in and out you need?
I can try to write it in arduino ide with stm support.
github.com/fdarling/mesa-smartserial-device-template
it looks complete, but it is only template without data definition for data in/out and of course main driving of stm pin (adc IO, timers etc).
M
Hey Martin - i'm finally getting back to this but seem to be overwhelmed with the STM IDE process.
wonder if you could do some hand holding for me.
I see someone started an arduino library(which might be easier for many) but it seems incomplete:
I have blue pill f1 (and some blackpill f4 coming).
I would like to make a Sserial to VFD interface.
Chris
Hi Chris,
M
21 Feb 2021 23:58 #199663
Replied by cmorley on topic USB haas operator panel interface
Sorry for the delay - I was away working.
My VFDs are Mitsubishi.
linuxcnc.org/docs/2.8/html/man/man1/mitsub_vfd.1.html
github.com/LinuxCNC/linuxcnc/blob/master..._comps/mitsub_vfd.py
I have an rs323 to rs480 module to add to the STM32 to control the VFD.
22 Feb 2021 21:39 #199772
by fupeama
I dont understand.
You want to comunicate by sserial from linuxcnc to bluepill and then by modbus from bluepill to vfd?
why?
M
I dont understand.
why?
M
23 Feb 2021 00:30 #199789
I use an Ethernet card with linuxcnc so the computer is separate from the i/o.
Currently I use the computer's serial port to control the spindle.
That's an extra cable to the computer.
If there is any loss of communication to the vfd it locks out in error - currently can only reset that by power cycle.
With a micro I could add a small relay to reset the vfd.
The python program to communicate to the vfd is a user program so can become unresponsive. sserial and micro should be more robust.
It gives example code that could be used for other sserial/STM32 projects.
Chris
Chris
- Mike_Eitel
- Thank you received: 185
23 Feb 2021 07:13 #199797
by Mike_Eitel
Replied by Mike_Eitel on topic USB haas operator panel interface
Hi Chris
Why not use the same serial as watchdog in the same time. No communication = you shutdown vfd after short delay (emergency break). Com on serial = give enable to vfd.
Easy to solv with a micro.
Mike
Mike
23 Feb 2021 09:51 #199809
while using a micro between the VFD and the computer in the system I have would be a fix for the ability to reset the VFD, it doesn't address the other issues.
Also I want to experiment with the STM32 as a sserial device.
06 Mar 2021 08:10 - 07 Mar 2021 01:01 #201162
by fupeama
Hi Chris,
that means you only need one IO.
Its ok. I try github.com/fdarling/mesa-smartserial-device-template . it is usable on stm32. there are 32bit in and 32 bit out.
the only thing i didn't find was the writing parameters. but that is not necessary now.
M
M
Last edit: 07 Mar 2021 01:01 by andypugh.
07 Mar 2021 01:02 #201242
Replied by andypugh on topic USB haas operator panel interface
That looks very interesting.
Does it create pins in HAL like a real sserial node?
07 Mar 2021 01:30 #201245
I started on that and needed to modify the code for strm32 - I didn't get it to work yet as I ran out of time for it.
Do you have code edits you could share?
Hi Chris,
M
Time to create page: 0.405 seconds
