Adding HAL Gremlin Plus widget causes glade crash
- LearningLinuxCNC
- Topic Author
- Thank you received: 61
26 Mar 2020 03:22 #161534
by LearningLinuxCNC
I am going through BigJohnT's tutorial at
gnipsel.com/linuxcnc/gui/gui02a.html
I am adding the HAL Gremlin Plus widget to my gui2.glade file and it causes glade to crash. This happens every time I add it to the window. I have tried to add it to different parts of the window and it crashes no matter where I add it.
Has anyone ran across this before?
26 Mar 2020 06:29 #161542
Replied by cmorley on topic Adding HAL Gremlin Plus widget causes glade crash
yes, but I don't remember if there was a work around.
The editor can be flaky.
adding actions can be problematic, work around this by right click and add as a top level widget.
What version of Glade are you using?
Chris
Chris
- LearningLinuxCNC
- Topic Author
26 Mar 2020 12:04 #161557
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Adding HAL Gremlin Plus widget causes glade crash
Chris,
Thanks for the reply. I am using Glade 3.8.0
I tried the add Gremlin widget as top level option and it also caused crash.
I have been able to add other actions as top level on the same glade file. Gremlin seems to be the main culprit.
Thanks,
Jim
Thanks,
Jim
26 Mar 2020 12:06 #161558
does the regular gremlin work?
- LearningLinuxCNC
- Topic Author
26 Mar 2020 23:09 #161629
by LearningLinuxCNC
Chris,
Yes the regular Gremlin does work. I was looking for it yesterday and I guess I was overlooking it in the tool tray.
That will work.
Thanks,
Jim
That will work.
Thanks,
Jim
27 Mar 2020 04:48 #161671
after your done you could hand edit the GLADE file and switch gremlin for gremlin plus.
Chris
Chris
Time to create page: 0.723 seconds
