DIPLAY = halui error
25 Apr 2020 19:44 #165571
by prochj51
DIPLAY = halui error was created by prochj51
I want to use LinuxCNC from command line so I want no axis gui. I have read
that I have to change DISPLAY = axis to DISPLAY = halui.
When I run this configuration I get error:
HAL: ERROR: duplicate component name 'halui'
HALUI: ERROR: hal_init() failed
I suppose that is because of the line
HALUI = halui
So when I comment it out, I get pin related error
./my_LinuxCNC_machine.hal:229: Pin 'halui.axis.x.select' does not exist
Would you know how I can overcome this?
Thank you
Jiri
HALUI = halui
Thank you
Jiri
25 Apr 2020 23:11 #165587
Replied by cmorley on topic DIPLAY = halui error
try adding the path to the INI file.
DISPLAY = halui -ini path/to/INI
26 Apr 2020 13:25 #165662
by prochj51
Replied by prochj51 on topic DIPLAY = halui error
Thanks for response.
Still says duplicate component.
I use LinuxCNC master branch.
Jiri
Jiri
26 Apr 2020 19:01 #165678
try removing the HALUI=halui
26 Apr 2020 19:26 #165681
by prochj51
then it says
I am attaching both ini and hal
27 Apr 2020 01:25 #165734
Well I tested and you can indeed load haui in the DISPLAY= entry.
My guess is that it doesn't wait till the halui component to finish before loading the HAL files, so the halui pins are not ready yet.
I would suggest finding a program you can load in the DISPLAY= entry that doesn't really matter and then continue loading halui in the HALUI=halui
My guess is the DISPLAY program must not end until you want linuxcnc to end.
27 Apr 2020 11:29 #165801
by prochj51
Yes,
thank you.
I made custom script myscript.py and I call
DISPLAY = myscript.py
works fine.
Thanks again.
Jiri
thank you.
works fine.
Thanks again.
Jiri
28 Apr 2020 01:21 #165886
great! could you share your program for the next person?
