What is the proportion in the GUI
26 Aug 2021 01:32 #218748
by yi2580
What is the proportion in the GUI was created by yi2580
I used GTK to do the GUI tutorial. Now I want to know what is the relationship between the coordinates of the XYZ axis in his interface and the mm and inch in reality. I hope someone can answer this question. thank you
26 Aug 2021 05:05 #218758
Replied by cmorley on topic What is the proportion in the GUI
I'm not sure anyone understands exactly what you are asking. Can you give more explanation or an example of what you are asking?
26 Aug 2021 09:37 #218778
by yi2580
Replied by yi2580 on topic What is the proportion in the GUI
01 Sep 2021 12:54 #219332
Replied by andypugh on topic What is the proportion in the GUI
If G0x1 sends X to 25.4 then that indicates that the G-code is in Imperial mode and the DRO display is in Metric mode.
Look at the G20 / G21 commands and also the display options of the GUI.
02 Sep 2021 05:40 #219400
by yi2580
OK, thank you very much for your reply. My question has been solved through your answer. Thank you very much
