Can't run Touchy with custom hal file
28 Aug 2021 13:43 - 28 Aug 2021 13:46 #219001
by envyvan
Can't run Touchy with custom hal file was created by envyvan
Hi Forks,
I try to swith my gui from AXIS to Touchy, I can run the Touchy with original core_sim.hal for simulation.
But after I swith to my custom hal file, It will show error message below.
If anybody can help would be appreciate.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.1
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.touchy'
Machine configuration file is 'touchy.ini'
INIFILE=/home/cnc/linuxcnc/configs/sim.touchy/touchy.ini
VERSION=1.1
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=touchy
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Found file(REL): ./config.hal
Running HAL command: loadusr gladevcp --always_above -c touchy_test touchy_test_panel.glade
Starting DISPLAY program: touchy
Issuing EMC_TRAJ_SET_TERM_COND -- ( +222,+24, +0, +2,0.000000,)
Issuing EMC_TRAJ_SET_G5X -- ( +224,+88, +0, +1,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,)
Issuing EMC_TRAJ_SET_G92 -- ( +227,+88, +0,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,0.000000,)
Issuing EMC_TRAJ_SET_ROTATION -- ( +226,+24, +0,0.000000,)
task: main loop took 0.011785 seconds
task: main loop took 0.017179 seconds
Issuing EMC_TRAJ_SET_TELEOP_ENABLE -- ( +230,+16, +1, +1,)
Issuing EMC_TASK_PLAN_SET_BLOCK_DELETE -- ( +518,+16, +2,\000,)
Issuing EMC_TASK_PLAN_SET_OPTIONAL_STOP -- ( +517,+16, +3,\000,)
Issuing EMC_TASK_PLAN_CLOSE -- ( +514,+12, +4,)
Issuing EMC_TASK_PLAN_OPEN -- ( +506,+268, +5,/tmp/tmpg0DlWA,)
Issuing EMC_TRAJ_SET_MAX_VELOCITY -- ( +207,+24, +6,1.666667,)
ini /home/cnc/linuxcnc/configs/sim.touchy/touchy.ini
COORDINATES = XYZABCUVW
TOUCHY postgui filename: touchy_postgui.hal
task: 3404 cycles, min=0.000760, max=0.017179, avg=0.001284, 2 latency excursions (> 10x expected cycle time of 0.001000s)
Debug file information:
Note: Using POSIX realtime
/usr/bin/touchy:79: GtkWarning: _gdk_drawable_get_source_drawable: assertion 'GDK_IS_DRAWABLE (drawable)' failed
pix = gtk.gdk.pixmap_create_from_data(None, pix_data, 1, 1, 1, color, color)
touchy_postgui.hal:9: Pin 'axis.x.jog-counts' was already linked to signal 'jog-counter'
1577
1601
Stopping realtime threads
Unloading hal components
I also attached the linuxcnc.report file.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.1
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=touchy
COORDINATES=X Y Z
KINEMATICS=trivkins
1577
1601
Last edit: 28 Aug 2021 13:46 by envyvan.
28 Aug 2021 16:51 #219023
Touchy also loads it's own postgui hal file named touchy.hal
That file must be present but it can be empty.
Replied by cmorley on topic Can't run Touchy with custom hal file
Right near the bottom it tells you the error.touchy_postgui.hal:9: Pin 'axis.x.jog-counts' was already linked to signal 'jog-counter'
The following user(s) said Thank You: envyvan
29 Aug 2021 12:47 #219096
by envyvan
Replied by envyvan on topic Can't run Touchy with custom hal file
Got it fix, Thanks.
Time to create page: 0.683 seconds
