Touchy MDI
- bednarzmac
09 Sep 2021 19:47 #220078
by bednarzmac
Touchy MDI was created by bednarzmac
Hi, i'm quite new into LinuxCnc world and I cant understand how MDI mode works in Touchy GUI. Where is command line? How can I write command made of some gcodes like G90 G54 G1 X30 Y30 F1000 ??? In Axis there is command line but how it works in Touchy? Only one code at a time (cycle start)?
Regards Maciek
Regards Maciek
10 Sep 2021 01:11 #220094
Replied by cmorley on topic Touchy MDI
press:the G/XY button
press 9 then 0
press cycle start
press G/XY
press 5 then 4
press cycle start
press G/XY
press 1
press next
press 30
press next
press 30
press next
press next
press 1000
press cycle start.
Touchy doesn't have a MDI command line.
Chris
press 9 then 0
press cycle start
press G/XY
press 5 then 4
press cycle start
press G/XY
press 1
press next
press 30
press next
press 30
press next
press next
press 1000
press cycle start.
Chris
The following user(s) said Thank You: bednarzmac
- bednarzmac
10 Sep 2021 09:57 #220115
by bednarzmac
Replied by bednarzmac on topic Touchy MDI
Thanks:) That is what i was afraid of.... I'll try to modify qttouchy to get command line.
10 Sep 2021 12:26 #220123
by BigJohnT
Replied by BigJohnT on topic Touchy MDI
You could create some macros for common things.
linuxcnc.org/docs/2.8/html/gui/touchy.html#_macros
JT
JT
05 Oct 2021 22:29 #222314
Replied by andypugh on topic Touchy MDI
I actually like the Touchy MDI. I think that it is a good fit for a touchscreen. And it also prompts you with all the right axis letters when you start a command.Thanks:) That is what i was afraid of.... I'll try to modify qttouchy to get command line.
06 Oct 2021 02:34 #222328
I've made a screen with an MDI history widget stacked under an MDI Touchy widget. a button will switch between showing each - best of both worlds.
06 Oct 2021 13:15 #222354
Ah, yes, I keep intending to add command history to Touchy. But it never gets to the top of the list.
Time to create page: 0.494 seconds
