GScreen limit switch issue
11 Feb 2022 12:55 #234568
Replied by cmorley on topic GScreen limit switch issue
Yes please post your original file.
I guess the file I based my changes to was newer then what you are using.
- Ivan_The_Red
11 Feb 2022 21:35 #234612
by Ivan_The_Red
Replied by Ivan_The_Red on topic GScreen limit switch issue
Thanks for continuing with this,i've attached my emc_interface.py file below so you can take a look at it and if you have any luck with it then Ill give it a shot.
Enjoy the weekend....cheers
11 Feb 2022 21:59 - 11 Feb 2022 22:00 #234615
Ok here is your modified file:
Last edit: 11 Feb 2022 22:00 by cmorley.
- Ivan_The_Red
12 Feb 2022 13:59 #234639
by Ivan_The_Red
the scrolling error seems to be fixed but theres another problem ..... when you turn the machine back on, the axis that tripped the limit switch takes off and wont stop until you hit estop or power the machine back off.
12 Feb 2022 22:47 #234665
ok here is another try.
Chris
Chris
- Ivan_The_Red
13 Feb 2022 14:57 #234698
by Ivan_The_Red
hi Chris, that worked perfectly....no more scrolling error messages and the axis stays put when the machines powered back up.
Can I venmo you a token of my appreciation? this isnt the first time youve taken time to help me out.
13 Feb 2022 18:35 #234716
Excellent!
I had to look up what Venmo was lol.
I appreciate the offer, but I'm just glad we got it fixed.
Happy machining.
Chris
Happy machining.
Chris
- Ivan_The_Red
14 Feb 2022 02:06 #234782
by Ivan_The_Red
Well, thanks again for your help.
Time to create page: 0.518 seconds
