LinuxCNC interaction with QT application
19 Feb 2022 13:15 #235326
by Guglielmi
LinuxCNC interaction with QT application was created by Guglielmi
Hello,
I would like to use LinuxCNC for my CNC and I'm thinking to install it on RPI4, I tested and it seems working fine. (it seems.. --> I didn't checked all feature, just if I'm able to provide a step/dir through GPIO ).
Well, not I would like to do an additional step, creating a QT small application that it has the task to control somethings, let me say, advanced on my CNC, like some temperature for motors, sensors for water cooling circuit, etc.. so basically a list of sensor I'm able to collect in my Raspberry but not directly through GPIO but for example through serial communication etc.. Ah, I forgot! The spindle it's a huge additional thing I want to control in my app with Modbus. So, parameter setup, diagnostic speed..
Ok, finally the question:
there is a way to interact with LinuxCNC? Do I need a special driver? I know for example the way to share memory but I don't have idea how to extract information inside LinuxCNC, by best target is for example to add a label on HMI to show motor temperature, or actual speed..
There is someone that already did something similar?
Thanks a lot
Andrea
Thanks a lot
Andrea
20 Feb 2022 19:19 #235411
by Grotius
Replied by Grotius on topic LinuxCNC interaction with QT application
On github there are several examples to be found.
This is a old example, not up to date, it contains nml a overflow bug, but it tell's you the basics how to interact.
Here are more advanched examples how to interact.
If you code in C or C++ you can code straight to the finish line by including lcnc's libs to your qt project.
That's nice. When coding for lcnc in C or C++, you can allocate memory by special hal functions. These hal functions
will create hal memory space for you.
Yes, that is a nice starting point. Maybe you can strip down the first link. And try it step by step.
For reference you could look in the next link how some hal things are done.
Good luck !
Good luck !
The following user(s) said Thank You: Guglielmi
21 Feb 2022 07:29 #235445
by Guglielmi
Replied by Guglielmi on topic LinuxCNC interaction with QT application
Thanks for really precise notes, I will try following your suggestions.
I appreciated a lot.
I leave open this loop in case I have details that make sense to ask.
Bye
Bye
11 Jul 2022 06:33 #247058
by udoS
Replied by udoS on topic LinuxCNC interaction with QT application
Hi Grotius
How/where could you find the number of joints and axis like in the ini file.
XYZY
joints = 4;
XYYZ
joints = 4;
How to get that info programmatically from within Qt;
Only from the Qt/c++; I don't want to read the .ini file.
Best Regards
XYZY
joints = 4;
XYYZ
joints = 4;
Best Regards
16 Jul 2022 11:14 #247447
Typical usage
Replied by andypugh on topic LinuxCNC interaction with QT application
I think you should read the INI file. There are library functions for the job, and that is the source of much of the infomation that the GUIs use.How to get that info programmatically from within Qt;
Typical usage
#include "emcIniFile.hh"
EmcIniFile *inifile
if inifile.open(filename) < 0 ........
int num_joints;
inifile->Find(&num_joints, "TRAJ", "JOINTS");
17 Jul 2022 08:25 #247544
by udoS
@andypugh ...
Thank you, yes that one I found already;
Now, since I use Qt, I also can use QSettings to read the .ini key, value pairs directly;
Best Regards
udoS
Best Regards
udoS
Time to create page: 0.168 seconds
