need help with gscreen
09 May 2022 22:53 - 09 May 2022 22:53 #242419
by thadwald
need help with gscreen was created by thadwald
Hi
I am working on a custom gscreen gui. I cannot figure out how to open a gcode file programmatically. Actually, what I would like to do is simply store the current file upon exit, then reload it when LCNC starts. I am able to store the current file but I cannot seem to open a new one.
I am a complete newbie to python, so any help will be appreciated. Pointers to working code examples or programming manuals would be particularly helpful.
Last edit: 09 May 2022 22:53 by thadwald.
- Thank you received: 5947
09 May 2022 23:15 #242421
Add the file name in the display section of the .ini file, file must be in the config folder, or add the full path to it.
Not sure if it works on GScreen though.
Replied by tommylight on topic need help with gscreen
[DISPLAY]
OPEN_FILE = cncbytoma.ngc
09 May 2022 23:40 #242429
by thadwald
Replied by thadwald on topic need help with gscreen
Unfortunately for me, gscreen does not appear to support OPEN_FILE ...
10 May 2022 01:14 #242448
by thadwald
I learned how to do this by looking at gmoccapy.py. Thanks!
You use the HAL widgets:
self.widgets.vcp_filechooser.set_filename(file)
self.widgets.vcp_action_open.load_file(file)
Time to create page: 0.197 seconds
