gscreen breaks with import matplot
03 Aug 2022 13:40 #248932
by thadwald
gscreen breaks with import matplot was created by thadwald
Hi
I am trying to use metplotlib for displaying a simple automated/guided CAM solution in gscreen (linuxcnc 2.8.2)
Following metplotlib tutorial, for using metplot with gtk2, I try the following line:
gscreen fails with the following error:
I suspect that maybe the import statement references gtk3 libraries but this is just a guess.
Any suggestions?
from matplotlib.backends.backend_gtk import FigureCanvasGTK as FigureCanvas
2
File "/usr/bin/gscreen", line 4661, in <module>
app = Gscreen()
File "/usr/bin/gscreen", line 792, in __init__
self.initialize_widgets()
File "/usr/bin/gscreen", line 1086, in initialize_widgets
self.init_dro_colors()
File "/usr/bin/gscreen", line 1196, in init_dro_colors
self.widgets.abs_colorbutton.set_color(gtk.gdk.color_parse(self.data.abs_textcolor))
File "/usr/bin/gscreen", line 228, in __getattr__
if r is None: raise AttributeError, "No widget %r" % attr
AttributeError: No widget 'abs_colorbutton'
Any suggestions?
03 Aug 2022 14:06 #248933
by thadwald
Replied by thadwald on topic gscreen breaks with import matplot
I have also tried
I get the same results
from matplotlib.backends.backend_gtkagg import FigureCanvasGTKAgg as FigureCanvas
03 Aug 2022 22:40 #248981
Replied by andypugh on topic gscreen breaks with import matplot
This looks like a funny one, maybe a namespace clash, for example.
Just as a check, if you comment-out the import matplot.... Does it all work again?
04 Aug 2022 00:06 #248990
by thadwald
Yes. It works fine with the other matplot import. It appears to be the gtk one that causes the problem.
04 Aug 2022 01:17 - 04 Aug 2022 01:20 #248992
Replied by cmorley on topic gscreen breaks with import matplot
have you tried your import just in a python session?
Gscreen some times hides the real error.
Did you check the terminal or is that error from the dialog box?
The terminal usually shows more.
But I would confirm the library imports all by it's self first.
You can also wrap a try statement around it:
then look in the terminal.
try:
except Exception as detail:
print (detail)
Last edit: 04 Aug 2022 01:20 by cmorley.
The following user(s) said Thank You: thadwald
04 Aug 2022 01:39 #248994
by thadwald
Thank you. There is actually an issue with the import statement and, like you said, gscreen was hiding it.
I have been running from terminal precisely to see these errors but this one didn't show up until explicitly trapped.
Thanks again!
Thanks again!
04 Aug 2022 13:16 - 04 Aug 2022 13:19 #249035
by thadwald
Follow-up
The root cause was that pip installs matplotlib by default without GTK C extensions.
using:
forces it to build the binaries, which then include the required GTK parts.
using:
pip install matplotlib --no-binary=matplotlib
Last edit: 04 Aug 2022 13:19 by thadwald.
Time to create page: 0.264 seconds
