Quickly iterating on UI?
15 Jan 2023 03:08 #262009
by JetForMe
Quickly iterating on UI? was created by JetForMe
Is there a way to quickly re-launch the UI application without having to completely restart LinuxCNC? Can I just launch my (from-scratch) UI executable and it will just "find" the running LinuxCNC?
15 Jan 2023 03:21 #262010
Replied by cmorley on topic Quickly iterating on UI?
Hard to say without code to look at.
but yes it's possible to run/reload a separate ui. That is what you are doing when you load a gladevcp panel.
15 Jan 2023 03:25 #262011
One way is to load say AXIS and the load your screen with a HAL command.
loadusr python3 myScreen.py
In this way AXIS can run the system as you develop the new screen.
Time to create page: 0.136 seconds
