Touchy + ngcgui
14 Apr 2023 10:41 - 15 Apr 2023 11:57 #269005
by scalaire
Touchy + ngcgui was created by scalaire
Hello everyone;
I configure my new CNC on a Beaglebone black with Machinekit.
Ngcgui works well on its own but I can't get it to work in Touchy, it creates a tab for me but it remains empty.
@++ Jean-Claude
@++ Jean-Claude
Last edit: 15 Apr 2023 11:57 by scalaire.
15 Apr 2023 08:22 #269069
Replied by andypugh on topic Touchy + ngcgui
Which Linux version / Gtk version / Python version.
I have a feeling that ngcgui might need modifications to work with Gtk3 and Python3
If you start from the command-line, do you see any clues in the output where it is going wrong?
(Command "linuxcnc" in a terminal window)
15 Apr 2023 11:36 - 15 Apr 2023 11:59 #269097
by scalaire
Replied by scalaire on topic Touchy + ngcgui
Hello,
Debian GNU/Linux 8.7 (jessie)
(bone-debian-8.7-machinekit-armhf-2017-02-12-4gb.img.xz)
Python 2.7.9
Python 3.42
How to see the version of Gtk?
scalaire00.free.fr/Install_Machinekit/Machinekit_01.jpg
Python 2.7.9
Python 3.42
Last edit: 15 Apr 2023 11:59 by scalaire.
15 Apr 2023 18:41 #269142
You seem to be using Machinekit?
Perhaps "get_linuxcnc_ini()" does not work with Machinekit?
I you want to investigate add a "print(p)" before line 209 of pyngcgui.py to see what it is trying to "split" on.
17 Apr 2023 07:51 #269281
by scalaire
A little better, I created a folder "linuxcn" and put my .ini file in it.
Now pyngcgui works in standalone but still doesn't want to be integrated in Touchy (Ngcgui also works in standalone).
In standalone there is no touch keyboard for Pyngcgui and Ngcgui.
22 Apr 2023 10:58 - 22 Apr 2023 11:06 #269600
by scalaire
I finally found it, I replaced the get_linuxcnc_ini_file() function
def get_linuxcnc_ini_file():
# example pgrep -lf output:
# 22224 linuxcncsvr -ini /path_to/somefile.ini
s = subprocess.Popen(['pgrep','-lf','linuxcncsvr']
,stdout=subprocess.PIPE
,stderr=subprocess.PIPE
p,e = s.communicate()
if s.returncode:
print(_('get_linuxcnc_ini_file: stdout= %s') % p)
print(_('get_linuxcnc_ini_file: stderr= %s') % e)
return None ans = p.split()[p.split().index('-ini')+1]
return ans .............................................................
Last edit: 22 Apr 2023 11:06 by scalaire.
22 Apr 2023 11:07 #269601
by scalaire
[/code]
[/code]
[/code]
by the latter
[code][code]=======================================
Linuxcnc SIM 2.7.14
ps = subprocess.Popen('ps -C linuxcncsvr --no-header -o args'.split(),
stdout=subprocess.PIPE )
p,e = ps.communicate()
if ps.returncode:
return None
return ans
[/code]
[code]If it helps anyone.
@++ Jean-Claude
Time to create page: 0.343 seconds
