QtDragon GUI
18 Jul 2023 00:47 #275697
by PedroSMS
QtDragon GUI was created by PedroSMS
Hi all,
I've just had a brief intro to qtdragon GUI - looks nice.
However, File menu - it doesn't have an address bar, nor does it keep it's last location. All my job files are on a network drive, and can't get to them...
Anyone have solution?
Kind regards
Pedro
Kind regards
Pedro
18 Jul 2023 06:39 #275716
Replied by cmorley on topic QtDragon GUI
I know nothing about network drives. How do you address to them generally?
18 Jul 2023 07:21 #275719
by rmu
Replied by rmu on topic QtDragon GUI
I don't know about address bar or if it keeps location, accessing network drives has nothing to do with that. Network drives work like everywhere else in linux, so if you can mount the drive somewhere it will be accessible. I use nfs to push NC files to the CNC machines.However, File menu - it doesn't have an address bar, nor does it keep it's last location. All my job files are on a network drive, and can't get to them...
19 Jul 2023 12:58 #275813
by PedroSMS
Replied by PedroSMS on topic QtDragon GUI
Thank you for your reply @rmu
I'm not an expert with debian.
However, linux doesn't normally automatically mount samba shares.
I know that some samba shares can be configured through the samba.conf file, but those arrangements are too rigid for my purposes.
I would prefer to enter the address "smb://ip_address//share_folder" into an address bar.
And, if that address bar could retain its last location, that would be very handy for me.
Kind regards
Pedro
Kind regards
Pedro
19 Jul 2023 14:09 - 19 Jul 2023 14:10 #275816
by rmu
I would advise against opening NC files directly from network drives. Linuxcnc opens and closes the file multiple times and unexpected things may happen if the network drive suddenly becomes unavailable. Windows used to do evil things with network shares with even short disconnections of what windows thinks is the physical link.
smb:// stuff in address bars usually is some functionality of a desktop environment that copies files to some temporary location and opens that.
IMO the better solution is to push nc files to the linuxcnc machine, e.g. via NFS, SMB, SSH or use a synchronised folder (syncthing, available for all major platforms except ios).
Last edit: 19 Jul 2023 14:10 by rmu.
19 Jul 2023 15:52 #275824
if seems network drives are disabled in pyqt5 for some reason:
stackoverflow.com/questions/42997657/pyq...show-network-folders
maybe the one ugly workaround works?
- Thank you received: 5949
19 Jul 2023 16:17 #275826
Replied by tommylight on topic QtDragon GUI
Anyone try "Warpinator" GUI for sending a receiving files over Linux network?
sudo apt install warpinator
Should be on both the sending and receiving files PC.
19 Jul 2023 23:52 #275838
by JohnnyCNC
Replied by JohnnyCNC on topic QtDragon GUI
I use WinSCP to move my files from the directory my .ngc files are posted to, to the nc_files directory on my LinuxCNC machine. I also use WinSCP to backup my linuxcnc directory to a shared folder on my NAS. There are many other similar tools. CoreFTP, Filezilla, etc. You just need to install OpenSSH on the Linux box.
20 Jul 2023 01:02 #275844
by phillc54
Replied by phillc54 on topic QtDragon GUI
My entire linuxcnc directory is a mount from a NFS share on a iMac. It has worked really well for several years.
20 Jul 2023 01:06 #275845
Replied by rodw on topic QtDragon GUI
I do similar. I used SAMBA and have allowed sharing of users home directory.
Its tricky to get Windows to connect as there are some policies that must be changed at the Windows end.
I have mapped my home folder to a Windows shared drive.
I just generate my gcode directly into the ncfiles folder from F360 on Windows
Time to create page: 0.151 seconds
