- User Interfaces
- Other User Interfaces
- int set_pin_FLOAT_calc(float, QString) sig velControl is not writable or not e
30 Oct 2023 22:03 #284150
by bkt
Based on these old .h file, try to write some pin .... but seems after upgrade to Lcnc2.10pre0 ... it not work properly ....in 2.9 all work perfect, in 2.10 pin not exist or not writable .... someone can send me in right direction?
in attach my heather (sorry for lot of comment, but was "original"):
int set_pin_FLOAT_calc(float, QString) ... these function connect all pin to qt gui ... and receive some error ..
20 Nov 2023 10:08 #286006
Replied by andypugh on topic int set_pin_FLOAT_calc(float, QString) sig velControl is not writable or not e
Did you get to the bottom of this? I just tried searching the code and did not find any instances of the function name, even in 2.9.
Maybe it is part of an external library? (QTPyVCP maybe?)
27 Nov 2023 22:54 #286644
by bkt
Replied by bkt on topic int set_pin_FLOAT_calc(float, QString) sig velControl is not writable or not e
is mine ... c/c++ qt .... but for sure other here use a quite similar code .... any how problem is solved .... unfortunately nor remember how and why ... but now code work .... think linking lcnc .a lib.
- User Interfaces
Time to create page: 0.126 seconds
