Modifier Axis
22 Feb 2013 13:50 - 22 Feb 2013 13:55 #30441
by finemeca
Modifier Axis was created by finemeca
Bonjour,
Y-a-t-il une possibilité de cacher, de remplacer une partie d'axis par un panneau en pyvcp ou en glade ?
Je veux dire supprimer certain boutons d'origine comme toucher, un peu à la manière de Gscreen
Merci
Pierre
Merci
Pierre
Last edit: 22 Feb 2013 13:55 by finemeca.
22 Feb 2013 15:29 #30442
by ArcEye
Replied by ArcEye on topic Modifier Axis
Hi
You cannot directly replace a gtk widget in Axis with one from glade say. The two are not compatible
You can remove that gtk widget and replace it with another on a glade panel that does the same thing, if you believe that it represents an improvement.
You will need to understand python, gtk and tcl.
Anything is possible, it is open source.
If you want to write your own or adapt GScreen that Chris wrote, you will need to study his threads and those of JT and direct specific questions to them
Is there a possibility to hide, replace part of an axis panel, in pyvcp or in glade?
I mean delete some original buttons as in GScreen
The following user(s) said Thank You: finemeca
02 Mar 2013 01:27 #30728
by finemeca
Replied by finemeca on topic Modifier Axis
Merci,
Actuellement, j'ai 6 machines qui tournent avec Axis, et je suis habitué aux panneaux pyvcp.
Faudra bien un jour que je passe à glade et à GScreen... Peux être dans la prochaine version stable de linuxcnc.
Merci pour ton aide et bon weekend.
Pierre
Pierre
Moderators: darty367
Time to create page: 0.163 seconds
