Homing button label too long ( solved )
08 Nov 2020 18:53 - 08 Nov 2020 19:53 #188681
by looping
Homing button label too long ( solved ) was created by looping
Hello
I'm using Axis with steppers.
The current french translation "Prise d'origine générale" for the homing button is much long than the English version "Home All".
This makes the "Manual control" tab larger and the right tabs smaller.
I'm using Probe screen v2 with a 1280x1024 resolution and the right part of the plugin is truncated.
The simulator uses "POM des axes" for this button and the sizes looks more like the English version and "Probe screen v2" tab is fine.
I made this modification in src/po/fr.po, recompile "linuxcnc.mo" and it's now fine.
Regards
Regards
Last edit: 08 Nov 2020 19:53 by looping.
- Thank you received: 5934
20 Nov 2020 19:01 #189913
Replied by tommylight on topic Homing button label too long ( solved )
Marked as solved.
21 Nov 2020 16:52 #189993
by looping
Replied by looping on topic Homing button label too long ( solved )
Here is the language file
Moderators: darty367
