Basic Pendant with 7i73
10 Mar 2019 14:25 #128241
by OT-CNC
Replied by OT-CNC on topic Basic Pendant with 7i73
rodw,
Will that work on axis as well? I often forget to switch out of the mdi tab before jogging. I don't have room for another switch, how about adding the teleop to my axis select switch in hal so I can toggle that to get me into jog mode?
10 Mar 2019 14:34 #128242
by OT-CNC
Mike_Eitel,
Nice control panel. I'm curious on your process for adding the graphics. All my panels are stainless and need labeling of sorts. I'm looking for professional looking results and they are already mounted so laser marking is out. What do you guys recommend? Sorry to getting a bit off topic here...
Have to draw the symbolic and probably try to get them laser printed on aluminium foil.
Mike
10 Mar 2019 19:11 #128265
Yes, it works fie with axis so any method to trigger a pin value in hal would work.
Replied by rodw on topic Basic Pendant with 7i73
rodw,
The following user(s) said Thank You: silopolis
02 Apr 2019 06:12 #130141
by pl7i92
Replied by pl7i92 on topic Basic Pendant with 7i73
the risk on this might be to get a loop and the pendant stands out
as you may turn the switch in undifined cases
Time to create page: 0.066 seconds
