Standalone electronic leadscrew (gearbox) mode for lathe
21 Jan 2020 01:39 #155289
by ttt
Standalone electronic leadscrew (gearbox) mode for lathe was created by ttt
This is an example of how to configure LinuxCNC to operate as a pure electronic leadscrew (or gearbox) for a lathe, without any CNC function.
Background: While I do some CNC machining with my converted lathe it turns out that in 95% of my uses cases I prefer using my lathe in classic manual mode, especially for quick projects. Until recently I used a custom solution to use my Z-axis stepper and spindle encoder to behave like an electronic leadscrew. While there have been requests to supply examples on how to do this in LinuxCNC I have never seen a working example.
The example consists of a standalone .hal file with a QtVcp based panel and supporting python code and is available here:
github.com/tinic/ElectronicLeadscrew
Hardware used:
- 7i96 Mesa board
- Clone/fake E6B2-CWZ6C Omron encoder
- Two generic DM680T stepper drivers for Z and X axis
- Two Nema 23 stepper to drive Z and X axis
Not sure how interesting this is for anyone here, but I thought I should at least post about it in case someone searches for a solution/hints. Questions are welcome.
Hardware used:
- 7i96 Mesa board
The following user(s) said Thank You: Mike_Eitel, joekline9, Nebur, tommylight, Benb, besriworld, anfänger, J Green, BeagleBrainz, Markyd and 1 other people also said thanks.
21 Jan 2020 03:01 #155293
by J Green
Replied by J Green on topic Standalone electronic leadscrew (gearbox) mode for lathe
Hi ttt
A very big thank you for sharing all of your efforts an the results.
Cheers
Bob
Cheers
Bob
25 Apr 2023 12:03 #269848
by michelko
Replied by michelko on topic Standalone electronic leadscrew (gearbox) mode for lathe
Hi just found your ELS Project. Exactly what i am looking for unfortunately i use the paralelport instead of an Mesa Card.
Will this work with the parallel Port too?
Thanks Michael
Thanks Michael
25 Apr 2023 12:15 #269850
Replied by PCW on topic Standalone electronic leadscrew (gearbox) mode for lathe
It should, You can do almost anything with a simple parallel port system
as you can with fancier hardware, there just will be some limitations
on step rates, PWM rates, and encoder resolution.
30 Apr 2023 19:09 #270326
by michelko
i tried to change to parallel poert but getting some errors on startup.
There is a window with this message:Traceback (most recent call last):File "/usr/bin/qtvcp", line 377, in <module>APP = QTVCP()File "/usr/bin/qtvcp", line 211, in __init__window.instance()File "/usr/lib/python2.7/dist-packages/qtvcp/qt_makegui.py", line 178, in instanceinstance = uic.loadUi(self.filename, self)File "/usr/lib/python2.7/dist-packages/PyQt5/uic/__init__.py", line 226, in loadUireturn DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/loader.py", line 72, in loadUireturn self.parse(filename, resource_suffix, basedir)File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 1013, in parsedocument = parse(filename)File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1182, in parsetree.parse(source, parser)File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parseself._root = parser.close()File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1671, in closeself._raiseerror(v)File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1523, in _raiseerrorraise errParseError: no element found: line 692, column 6
30 Apr 2023 19:15 #270328
by michelko
iam not good in programming so can someone help out, please?
Here is whats the Terminal is showing:
Cant post the terminal message. Says: to many links in your Message
What am i doing wrong?
Regards
Regards
30 Apr 2023 19:17 #270329
by michelko
16 Oct 2023 09:28 - 16 Oct 2023 09:29 #283112
by michelko
at leats i got i running with my parallel Port setup.
One problem left:
in the HAL are those sections one for x and one for z
net x-control-type <= lathe_ui.control_x_type
net x-control-type => hm2_7i96.0.stepgen.01.control-type
net x-velocity-cmd <= lathe_ui.velocity_x_cmd
net x-velocity-cmd => hm2_7i96.0.stepgen.01.velocity-cmd
The problemis in the second and the fourth line
I don´t know how to switch this to the parport stepgen commands.
As far as i understand the Hal those are used for jogging with the cursor buttons, but maybe i am wrong.
Any ideas??
Thanks in advance
One problem left:
Any ideas??
Thanks in advance
Last edit: 16 Oct 2023 09:29 by michelko.
16 Oct 2023 20:02 #283139
by Markyd
Replied by Markyd on topic Standalone electronic leadscrew (gearbox) mode for lathe
Will this work with only one stepper (on the main leadscrew)?
17 Oct 2023 05:15 #283158
by michelko
Yes but then the facing and taper function won`t work
