Mollum and StepperOnline EV200 series VFD
- echristley
- Thank you received: 21
20 Aug 2023 20:46 #278569
by echristley
Mollum and StepperOnline EV200 series VFD was created by echristley
This is what I ended up with to get my Mollum VFD working. While searching for answers as I worked this out, I found that the EV200 series of VFDs from StepperOnline appear to have the exact same command set. My situation may be different from most, in that I have a mechanical switch to choose forward and reverse, and I tied that switch into the operation of the machine. Also, I have yet to get the speed override and feedback working. But this is enough to get the machine running.
The following user(s) said Thank You: smc.collins, OGMaker
Time to create page: 0.170 seconds
