Moving an axis to a particular distance using hal command.
29 Feb 2024 12:28 #294767
by Aravind
Problem: Need to move 4th axis to a certain distance (say 100mm) using hal command.
I am configuring a machine where I need to move my 4th axis to certain distance (say 100mm) and I am trying to do it on a particular sequence in my ladder logic.
When a particular switch is activated, I want my 4th axis to move to this distance and stop. I was thinking that it could be possible if I assign the distance value to the position command pin joint.3.motor-pos-cmd. But I was wrong in that. It was an output from LinuxCNC GUI (I hope so). I couldn't find any other input pin for assigning the position command.
Is there any option for moving an axis to a certain distance from hal command.?
Hardware: EC500_v5 with remora firmware.
I am a beginner to LinuxCNC. Kindly help me in this learning process.
Hope to get a response.
-Aravind.
-Aravind.
- Thank you received: 5942
29 Feb 2024 13:20 #294771
Replied by tommylight on topic Moving an axis to a particular distance using hal command.
Just a stab in the dark, but maybe using hal to monitor the pin then activating an MDI command that runs certain gcode to move the axis/joint?
PyVCP panel can run MDI by clicking on buttons on screen, so just making that button controllable by physical switch should be doable.
01 Mar 2024 09:36 #294827
by Aravind
Replied by Aravind on topic Moving an axis to a particular distance using hal command.
Is there any other method in which I can move the axis to a particular distance from classicladder ladder logic.?
-Aravind
-Aravind
01 Mar 2024 12:33 #294836
by spumco
Replied by spumco on topic Moving an axis to a particular distance using hal command.
Does the movement need to occur in the middle of a running G-code program?
Is the distance to be moved always the same?
01 Mar 2024 12:48 #294838
by Aravind
[ISSUE SOLVED]
Added a section in INI file for MDI command.
Now I got halui.mdi-command-00 under Pins > halui mdi_command-00 in HAL Configuration window which I could run by a true command. And I was able so net one output variable in classicladder to this pin and was able to move the axis for the required distance.
-Aravind.
[HALUI]
MDI_COMMAND = G1 F500 A0
MDI_COMMAND = G1 F500 A50
-Aravind.
Time to create page: 0.080 seconds
