Installing a Custom GUI
19 Aug 2012 13:55 #23394
by BigJohnT
Installing a Custom GUI was created by BigJohnT
I have stumbled across how to install your custom GUI so you can run it with linuxcnc path to your ini.
The details are in my Custom GUI Tutorial part 3.
Almost at the same time I found out how to run an application at start up . It's dead nuts simple you just add it to your System > Preferences > Startup Applications and when you boot up it runs.
The following user(s) said Thank You: Boogie
21 Sep 2012 12:13 #24508
by meduag
Replied by meduag on topic Re:Installing a Custom GUI
Hi BigJohnT.
first of all thanks for your tutorials
One question, how I can use the EMC SourceView?
how I can add a different code, of the code G (inside SourceView EMC) using python?
look your tutorials to create a GUI, but still there is no signal for the tab "G Code"
Pdt:
excuse me I do not know much English
disculpame no sé mucho ingles.....
desculpe-me eu não sei muito inglês...
Pdt:
21 Sep 2012 14:34 #24516
by BigJohnT
Replied by BigJohnT on topic Re:Installing a Custom GUI
Thanks,
The EMC Sourceview is a GladeVCP part and is self contained to show the currently loaded G code file. I think to do some other task with python you would need to use the GTK sourceview and program it in python. I've not done that yet.
Time to create page: 0.248 seconds
