When to use what label?
17 Mar 2014 15:56 #44912
by mariusl
Regards
Marius
www.bluearccnc.com
When to use what label? was created by mariusl
Hi
Please help me understand when to use what label. They way I currently understand it is as follows:
A hal_label widget is connected directly to the hal interface and does not go to my python handler. I dont know if I can see it or intercept it in my handler.
A gtk_label is can be written by my python handler. I have to create a hal_pin in the handler to look at and then effect the label if I wish.
So the question is really when do I use what label for best practise?
Regards
Marius
www.bluearccnc.com
18 Mar 2014 02:52 #44931
by newbynobi
Replied by newbynobi on topic When to use what label?
Hallo Marius,
in most cases if you just want to display a hal value or modify a value, it is the easiest way to use just a hal widget, may it be a label or any other widget.
If there is no widget, giving you all the flexibility you need, then take a normal gtk widget and add the pins and handlers as you need in your python handler file.
If you need a hal pin:
Try first hal widget, and if not OK use gtk.widgets with you own handler file
If you do not need a Hal Pin for your panel, i.e. a table to arrange your widgets:
never use a hal widget for that purpose!
Norbert
Norbert
18 Mar 2014 12:30 #44943
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic When to use what label?
Hi Norbert
Thanks for the reply. I think I understand but as with most things, you learn as you go.
I have more problems understanding GTK than I do with Python at this stage
Regards
Marius
www.bluearccnc.com
18 Mar 2014 19:16 #44948
by BigJohnT
I have some tutorials on Python GTK Glade.
gnipsel.com/glade/index.html
JT
Replied by BigJohnT on topic When to use what label?
Hi Norbert
JT
18 Mar 2014 19:29 #44949
by newbynobi
And the tutorials are very good, I learned a öot of them!
Norbert
Norbert
19 Mar 2014 01:17 #44958
by mariusl
Regards
Marius
www.bluearccnc.com
Thanks JT, have learnt a lot from your site already. I will check out the tutorials.
If its good for Norbert then its good for me.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.203 seconds
