GtkEntry Cursor
25 Feb 2015 01:45 #56278
by BigJohnT
GtkEntry Cursor was created by BigJohnT
I have a GtkEntry on a tab embedded into Axis but the cursor does not show up when you click on the entry box. It's there and you can type but you have no clue your there. I've looked through the options in glade and don't see anything. Is this another tcl focus issue?
JT
JT
25 Feb 2015 01:56 #56279
by mhaberler
Replied by mhaberler on topic GtkEntry Cursor
try running the glade window outside Axis, ie not as an embedded tab
if the problem goes away, the answer is yes
-m
-m
25 Feb 2015 21:38 - 25 Feb 2015 21:40 #56290
by BigJohnT
Replied by BigJohnT on topic GtkEntry Cursor
Well it is correct the missing cursor is the tcl problem. I ran it stand alone and the cursor shows up normally. However the axis-remote works to send the file to axis so this might be a better solution. Just need to figure out how to load the GladeVCP panel when axis loads...
JT
JT
Last edit: 25 Feb 2015 21:40 by BigJohnT.
25 Feb 2015 21:57 #56291
by BigJohnT
Any idea what causes this error?
JT
** (gladevcp:3151): CRITICAL **: glide_draw_box_gap: assertion `height >= -1' failed
JT
25 Feb 2015 22:00 #56292
by mhaberler
26 Feb 2015 02:36 #56296
by BigJohnT
Interesting I only get that error if there is a notebook and I embed the glade into a tab in Axis. I can run the same glade file with a loadusr command in my postgui.hal and no error.
JT
JT
28 May 2016 02:38 #75177
by squan09
Replied by squan09 on topic GtkEntry Cursor
Were you able to get the cursor to show? I am working on an embedded tab in axis and have the same problem. I am also unable to read the entry box using get_text() in the embedded tab. Using the changed signal I am printing to the terminal I am printing the current value of the entry box. When I type into the entry box in the embedded tab the signal is triggered, but the value is not changed. It just prints out an empty string which is the initial value of the entry box. If I show the window outside of the embedded tab though everything works as expected.
I also have a similar problem setting label text. On a button click I can change a label when in a separate window, but not in the embedded tab. Any idea what I need to do to solve this?
02 Jun 2016 13:57 #75332
On my lathe macro screens I have a button that calls an O-word sub using the {hal_pin} syntax described here:
www.linuxcnc.org/docs/html/gui/gladevcp....leaction_mdi_widgets
Replied by andypugh on topic GtkEntry Cursor
I have just got used to this. It's annoying, though.Were you able to get the cursor to show? I am working on an embedded tab in axis and have the same problem.
I haven't tried using get_text(), but for many LinuxCNC applications you might be able to do things a different way.I am also unable to read the entry box using get_text() in the embedded tab
02 Jun 2016 19:59 #75358
by squan09
Thanks for the reply. I'll have to look into calling O-word subs. I was able to get the get_text() function to work though. I think my problem was in the __init__ I called self.builder.add_from_file('glade_file.glade') and self.builder.connect_signals(self).
After reading some more it looks like connect_signals is automatically called during initialization, so I guess it was confusing something. After I commented out those 2 lines the get_text() function works along with set_text() which I was having trouble with using on labels.
Time to create page: 0.160 seconds
