XY/UV axis config
13 Oct 2015 10:07 #63729
by fannlow
XY/UV axis config was created by fannlow
Hi Guys,
I have added to my .ini file
[Display]
Geometry = XY;UV
FOAM = 1
What this does is showed me the Axis GUI in the form of XY & UV.
however, the issue being that the representation insist that the Z-axis is still there...
not sure why, the XY is lying flat on the floor, with Z in the middle as the normal Z axis, and above the Z-axis is the UV axis.
is there any way, I can perhaps tilt this GUI somewhere in my .ini file or axis file for this to show up correctly?
X & U = horizontal axis
Y & V = vertical axis
thanks in advance
[Display]
Geometry = XY;UV
FOAM = 1
thanks in advance
13 Oct 2015 18:54 - 13 Oct 2015 18:55 #63743
Replied by andypugh on topic XY/UV axis config
If you look at the foam sample config
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...6e14b28883fe;hb=HEAD
It also has
Try that.
It also has
[TRAJ]
AXES = 9
COORDINATES = X Y U V
Try that.
Last edit: 13 Oct 2015 18:55 by andypugh.
The following user(s) said Thank You: fannlow
13 Oct 2015 19:12 #63744
by cncbasher
Replied by cncbasher on topic XY/UV axis config
not at this moment , it would need changes to Axis Gui ,
13 Oct 2015 19:35 #63748
The Foam display did include changes to the Axis GUI, wasn't removing Z one of them?
17 Oct 2015 02:14 #63850
by fannlow
Replied by fannlow on topic XY/UV axis config
I will try that when I get back to the office.
thanks for the help!
Time to create page: 0.299 seconds
