HAL_Button accelerator
26 Jul 2016 11:24 #78034
by bodhi_94
HAL_Button accelerator was created by bodhi_94
How to assign a accelerator key to activate HAL button on glade vcp.. I assign accelerator to a hal button. But when i press the button,The hal value is not change...
26 Jul 2016 15:43 #78046
by newbynobi
Replied by newbynobi on topic HAL_Button accelerator
The glade GUI must be active to receive the keyboard shortcut. If it is embedded, the main program must pass that key through.
Norbert
Norbert
The following user(s) said Thank You: bodhi_94
27 Jul 2016 05:16 #78060
by bodhi_94
Replied by bodhi_94 on topic HAL_Button accelerator
Could you please explain more?
27 Jul 2016 13:37 #78067
by newbynobi
Question:
- is your glade panel embedded or stand alone?
- do you have a handler file for it, or does it only show hal widgets.
- What GUI do you use (syis ; gmoccapy; touchy, ....
Post your code, it is easier to help with that one.
Norbert
Norbert
29 Jul 2016 04:39 #78125
by bodhi_94
Glade is running stand alone.
AXIS
I assigned accelerator to a button from glade common tab.When i press the key which was assigned to the button,Button was highlighted but it is not become TRUE.
AXIS
29 Jul 2016 07:39 #78127
by newbynobi
Post your code, so we can reproduce the behavior.
Norbert
Norbert
Time to create page: 0.071 seconds
