incremental jog feedrate problem
- Ivan_The_Red
14 Jan 2017 02:04 #85719
by Ivan_The_Red
incremental jog feedrate problem was created by Ivan_The_Red
I building an arduino pendant to use wih gscreen and everything is almost finished and ive ran into a problem i cant figure out , heres the situation.
When i run a cnc program i can use the feedrate potentiometer through the arduino and it works perfectly to change the feedrate as the program runs...no problem
When i enter mdi mode and enter a simple linear move the potentiometer still functions as expected.
When i use the keyboard to manuall jog an axis the potentiometer still functions perfectly.....now the oddity.
When i select an incremental jog and jog the axis the potentiometer doesnt work to adjust the feedrate and i cannot figure out why.
Any help would be greatly appreciated
Thanks....Jeff
Thanks....Jeff
- Thank you received: 2164
14 Jan 2017 08:23 #85730
Replied by cmorley on topic incremental jog feedrate problem
I don't see anything obvious in gscreen's code. Can you post your modifications?
Chris M
Chris M
- Ivan_The_Red
14 Jan 2017 22:59 #85787
by Ivan_The_Red
Replied by Ivan_The_Red on topic incremental jog feedrate problem
Hey Chris , thanks for helping me tgrough all of these issues. I loaded up Gmocappy and used the sliders on that interface and it exibits the same behavior as mine does when using my arduino , could it be that linuxcnc is unable to dynamically adjust incremental feed commands?
Jeff
Jeff
15 Jan 2017 01:30 #85801
According to the python interface to linuxcnc incremental speed can be set.:
from www.linuxcnc.org/docs/2.7/html/config/py..._linuxcnc_command_tt
c.jog(linuxcnc.JOG_STOP, axis)
c.jog(linuxcnc.JOG_CONTINUOUS, axis, speed)
c.jog(linuxcnc.JOG_INCREMENT, axis, speed, increment)
I am not sure how you are setting jog velocity or what other customizations you have done, so I can't help further until i do.
Chris M
Chris M
15 Jan 2017 01:31 #85803
Gmoccapy was originally a skin of Gscreen so I am not surprised if there are common idiosyncrasies.
Chris M
Chris M
- newbynobi
- Thank you received: 394
15 Jan 2017 13:10 #85815
by newbynobi
Replied by newbynobi on topic incremental jog feedrate problem
I just checked that on gmoccapy 2.2.3 , sim/gmoccapy/gmoccapy.ini
- out of estop
- switch on the machine
- home all
- jog with the jog buttons, all OK
- select 1.2345 in Jog increment
- lower the jog vel slider (just push turtle mode)
- push any axis button once
If you look at the velocity label, you will see, that my GUI is handling that correct!!!!
I also checked the code from gscreen, it is very similar and I am pretty sure it should behave correct as gmoccapy does.
Please check you config!
Norbert
- out of estop
- home all
Norbert
- Ivan_The_Red
15 Jan 2017 14:42 #85818
by Ivan_The_Red
Thats whats happening with mine as well except if you try to adjust the feedrate during the move mine wont change the feedrate , it remains at the feedrate that it started with. Can you change the feedrate while yours is moving ?
- newbynobi
15 Jan 2017 17:01 #85826
by newbynobi
Hallo Ivan,
no, that is not possible, once the move has begone, you are not able to change the velocity till the move ends.
The commands has been send, so you will not be able to change its parameters.
Norbert
Norbert
- Ivan_The_Red
15 Jan 2017 21:58 #85862
by Ivan_The_Red
Hi Norbert ,
Thanks for taking the time to look into that for me i really do appreciate that. I was hoping that was the case because i had no idea how to make that work....i tried everything i could.
Have a great day
Jeff
Have a great day
Jeff
Moderators: HansU
Time to create page: 0.159 seconds
