Gladevcp grayed out
- AThayer
12 Mar 2017 14:04 #89465
by AThayer
Gladevcp grayed out was created by AThayer
Ok I configured a simulated milling machine. I added a gladevcp which displays. The issue I am having is the panel is grayed out even after pressing e stop and power button. I don't know if it is something I did or something I need to do. Anyone have any ideas?
- Thank you received: 2147
12 Mar 2017 16:51 #89473
Replied by cmorley on topic Gladevcp grayed out
Hard to answer definitively without more info but:
There are container widgets that grey-out (made insensitive in GTK speak).
These are: state_sensitive_table and hal_sensitive_table.
HAL_sensitive_table has a HAL pin that must be set true to make them sensitive to input.
State_sensitive_table depends on the state of linuxcnc. There are selectable states to react to.
Did you home the machine? If you have a state_sensitive_table I would bet it's set to wait for all-homed.
Chris M
Chris M
- AThayer
12 Mar 2017 18:55 #89479
by AThayer
Replied by AThayer on topic Gladevcp grayed out
Thanks Chris where would I find these widgets and how to I edit them?
12 Mar 2017 20:50 - 12 Mar 2017 20:51 #89489
use the GLADE editor to edit the .glade file.
on the right hand side of the editor, it should list the widget hierarchy.
Change the sensitive table to a regular table.
But really if the sensitive table is a state sensitive table it probably was put there in the first place for a good reason.
Chris M
Chris M
Last edit: 12 Mar 2017 20:51 by cmorley.
Moderators: HansU
Time to create page: 0.076 seconds
