Error when using VCP Actions
25 Jun 2018 13:16 #112845
by cgibbons
Error when using VCP Actions was created by cgibbons
Hi there,
I am running LinuxCNC 2.7 and Glade 3.8.6 on Raspbian Stretch.
I can get the HAL Python and VCP Actions to show up in my Glade Palette on the left when I runin the same terminal I am running LinuxCNC from.
However, when trying to create a new interface while following this tutorial , everything works fine until I add the VCP ToggleAction ESTOP. Then I get the following errors in my terminal and sometimes Glade just crashes and closes.
I have read many forum posts and google links trying to find the answer to this but have been unable to solve it. Any help would be greatly appreciated.
glade-3
(glade-3:23977): Gtk-CRITICAL **: IA__gtk_notebook_insert_page: assertion 'GTK_IS_WIDGET (child)' failed
(glade-3:23977): Gtk-CRITICAL **: IA__gtk_notebook_set_tab_label: assertion 'GTK_IS_WIDGET (child)' failed
(glade-3:23977): GladeUI-GTK-CRITICAL **: Unbalanced children when inserting notebook children (pages: 0 tabs: 1 extra pages: 0 extra tabs 0)
Issuing ESTOP
File "/home/pi/linuxcnc-2.7/lib/python/gladevcp/hal_actions.py", line 99, in _f
return f(self, *a, **kw)
File "/home/pi/linuxcnc-2.7/lib/python/gladevcp/hal_actions.py", line 209, in on_toggled
self.linuxcnc.state(linuxcnc.STATE_ESTOP)
AttributeError: 'EMC_ToggleAction_ESTOP' object has no attribute 'linuxcnc'
Issuing ESTOP RESET
File "/home/pi/linuxcnc-2.7/lib/python/gladevcp/hal_actions.py", line 212, in on_toggled
self.linuxcnc.state(linuxcnc.STATE_ESTOP_RESET)
Issuing ESTOP
Issuing ESTOP RESET
25 Jun 2018 14:07 #112847
Replied by andypugh on topic Error when using VCP Actions
The offending line in the handler code is here:
github.com/LinuxCNC/linuxcnc/blob/master.../hal_actions.py#L205
The VCP on/off button has the same structure, does that work?
Is the output above from a running linuxCNC instance, or from an attempt to run the screen standalone?
25 Jun 2018 14:25 #112849
by cgibbons
Replied by cgibbons on topic Error when using VCP Actions
I have looked at this line in the code before but it doesn't help me fix the error.
The actions do not show up in my inspector on the right hand side of my screen in glade. Once I click on some other widget, I cannot find the action anywhere.
I have tried those too but i get these error messages in my terminal:The VCP on/off button has the same structure, does that work?
(glade-3:24712): Gtk-CRITICAL **: IA__gtk_container_add: assertion 'GTK_IS_WIDGET (widget)' failed
(glade-3:24712): Gtk-CRITICAL **: IA__gtk_container_child_set_property: assertion 'GTK_IS_WIDGET (child)' failed
These error messages are all in the terminal while I am running Glade.Is the output above from a running linuxCNC instance, or from an attempt to run the screen standalone?
25 Jun 2018 15:05 #112851
There won't be a linuxcnc object for the GladeVCP to link to unless LinuxCNC is running.
You can probably ignore the e-stop warnings. It might be interesting to see if they go away if LinuxCNC is actually running at the time.
25 Jun 2018 17:06 #112854
Replied by cmorley on topic Error when using VCP Actions
You can try right clicking the action and add as a top level.
In general you should save your work often - GLADE can be glitchy.
Chris M
Chris M
25 Jun 2018 17:50 #112856
I think that is an understatement. To the extent that once I have a panel set up I don't dare try editing it with Glade, I use a text editor
I got the feeling that the newer version (which doesn't work with LunuxCNC) was more responsive and less glitchy.
26 Jun 2018 09:25 #112870
by cgibbons
Right clicking and adding it as a top level, makes it show up in my inspector on the right, whether I have linuxCNC running or not. Thank you cmorley.
I am going to have LinuxCNC running in the background from now on anyway, though LinuxCNC doesn't seem to be appearing as an object either way.
I am running glade/linuxcnc from different shell windows (as I wouldn't be able to run them both from the same window at the same time), that doesn't matter does it? As far as I know I can't run them both from the same shell window.
26 Jun 2018 09:28 #112871
If you use "linuxcnc &" then linuxcnc will launch and return control to the shell.
bashitout.com/2013/05/18/Ampersands-on-the-command-line.html
26 Jun 2018 10:09 #112873
by cgibbons
Oh great, Thank you! I have been using the terminal an insane amount in the last two years, can't believe I never came across this.
Time to create page: 0.474 seconds
