Glade Spindle Speed Meter
13 Dec 2018 18:54 #122382
by mmt
Glade Spindle Speed Meter was created by mmt
I have a lathe setup that I have been using for quite some now.
I have a pyvcp spindle speed indicator that step config create and it measures actual speed from an encoder and works great.
I created a gladevcp panel with a spindle speed meter and the only thing changed in my postgui.hal file was from pyvcp to gladevcp.hal_hbar1. (sorry not at the machine for the exact change) and it works but the speed reading is carried out many many decimal places and lags very bad.
I can not figure out why this is?
Any help would be appreciated. Let me know if you need more info.
13 Dec 2018 20:36 #122384
Replied by cmorley on topic Glade Spindle Speed Meter
In Gladevcp editor change the Hbar's 'text template' property to
%3.1f
I think that should do it.
(pyvcp bar uses this as default)
%3.1f
The following user(s) said Thank You: mmt
Time to create page: 0.082 seconds
