net a parameter like #4191 to a gladevcp.hal_label
28 Dec 2018 14:23 #123019
by partec
net a parameter like #4191 to a gladevcp.hal_label was created by partec
net a parameter like #4191 to a gladevcp.hal_label ?
some gladevcp.hal.button are used
with VCP Action MDI Command #4191 = <_y> e.g.
to store teach in positions
it works fine using the file
linuxcnc.var
4191 68.045000 individual parameters
.... individual parameters
4232 0.000000 individual parameters
5161 0.000000 standard parameters
.... standard parameters
5390 0.000000 standard parameters
how should it be configured now, to net a parameter like #4191 to a gladevcp.hal_label ?
linuxcnc.var
29 Dec 2018 15:45 #123091
by pl7i92
Replied by pl7i92 on topic net a parameter like #4191 to a gladevcp.hal_label
you may look here
www.linuxcnc.org/docs/html/gui/gladevcp....mand_on_button_press
The following user(s) said Thank You: partec
Time to create page: 0.536 seconds
