How do I open a file with IconFileSelect? (partially solved!!!)
06 Feb 2019 22:33 #125886
Replied by cmorley on topic How do I open a file with IconFileSelect? (partially solved!!!)
oops saw another typo
def on_file_selected(self,widget,data=None):
md = gtk.MessageDialog(None,
gtk.DIALOG_DESTROY_WITH_PARENT, gtk.MESSAGE_QUESTION,
gtk.BUTTONS_YES_NO)
md.run()
path = self.builder.get_object('file').get_selected()
print path
md.destroy()
06 Feb 2019 23:16 #125888
by pferrick
Replied by pferrick on topic How do I open a file with IconFileSelect? (partially solved!!!)
Here's what I got (I ran linuxcnc from the command line):
File "./file.py", line 20, in on_file_selected
gtk.BUTTONS_YES_NO, path)
UnboundLocalError: local variable 'path' referenced before assignment
So I re-arrranged things slightly, like this:
print path
md.run()
md.destroy()
and I got this:
File "./file.py", line 18, in on_file_selected
File "/usr/lib/pymodules/python2.7/gladevcp/iconview.py", line 423, in get_selected
return on_btn_get_selected_clicked(self)
NameError: global name 'on_btn_get_selected_clicked' is not defined
The first one kinda made sense to me, but that last one....????!?!?! There are no other widgets on the glade window (nor are there any named btn anywhere, AFAIK.
Any ideas? I really appreciate your help, Chris. Thank you.
print path
md.run()
md.destroy()
and I got this:
06 Feb 2019 23:23 #125890
try the last one I posted
Chris
Chris
06 Feb 2019 23:44 #125892
I'm looking at your code and finally realize that your dialog is built on the fly - and does not have the icon view put in it....So maybe I am missing something.
To help you any further I need the GLADE file.
Chris M
Chris M
06 Feb 2019 23:52 #125893
by pferrick
I tried it again and got pretty much the same thing:
I'll attach both the python and the glade files.
PKF
PKF
07 Feb 2019 00:52 - 07 Feb 2019 00:53 #125900
by pferrick
Chris-
In case it isn't obvious...I'm only attempting to use a messagebox as a diagnostic tool. Y'know, something to clue me in to the value of a variable. I'm expecting the message to be the path, of course.
I've actually done quite a lot of "recreational" coding over the years, mostly with Visual Basic and the like. A little C here and there, and now I'm tackling Python. So not much "real" programming, I guess you could say! I'm now trying to buckle down and learn what classes, constructors, widgets, methods, etc. are all about.
Last edit: 07 Feb 2019 00:53 by pferrick.
07 Feb 2019 06:52 #125905
Ok here is the python code; I added an vcp_action_open object to the GLADE file.
I add comments that should explain - feel free to ask specific questions.
BUT:
I'm not sue what screen you are using:
I have discovered (not surprisingly) it doesn't work well if you are using AXIS.
AXIS does not notice program changes in the motion controller - so the screen does not update and if you use the reload
button it reloads the last program that AXIS knows about. I'm sure there is a work around - i'd have to look into it.
If you use Gmoccapy or Gscreen it will work fine.
Also i see there really is little documentation on most actions - i don't image you could have figued out how it worked without looking at the source (which is what i did!)
Chris M
BUT:
import gtk
import gladevcp
import linuxcnc
import pygtk
import hal
import os
class HandlerClass:
def __init__(self, halcomp, builder, useropts):
# make a class reference to builder
# (self.ANYTHING is available anywhere in the HandlerClas class)
self.builder = builder
# make a class reference to the open vcp_action
self.open = builder.get_object('open')
# change a property in the iconchooser so all programs show
# this shouldn't be required - it's a bug
builder.get_object('file').set_property("filetypes", '*')
# This is a callback function from the icon chooser selected in the GLADE signal editor
# in GTK the first variable is always the widget that owned the signal that called this function
# any other variables depend on the widget, in this case icon view sends the path
def on_file_selected(self, widget, path):
print path
if path:
self.open.load_file(path)
# boiler code
def get_handlers(halcomp,builder,useropts):
return [HandlerClass(halcomp,builder,useropts)]
Chris M
08 Feb 2019 02:08 #125970
by pferrick
Hi Chris-
Thanks for the detective work! I am using AXIS, so I found as you did that while the code you suggested does return a path but isn't so good at opening a file with it.
I'm playing around with some other possibilities which I'll fill you in on soon. I haven't given up yet, since I have quite a high tolerance for feeling like a complete idiot, apparently!
regards,
Patrick
regards,
Patrick
08 Feb 2019 09:22 #125985
Ok You can use axis-remote to load programs in AXIS.
In this case you can remove the vcp_action_open from the glade file.
Chris M
import subprocess
class HandlerClass:
if path:
print path
subprocess.call('axis-remote %s' % path, shell=True)
# boiler code
Chris M
08 Feb 2019 23:04 #126023
by pferrick
Chris-
I'm right in the middle of trying exactly that. Right now I'm trying to iron out a little problem with using .axisrc to switch AXIS tabs via GladeVCP buttons. But I'm pretty sure when that's taken care of the file-opening situation will also work. That means my whole interface will be working, which will make me extremely happy!
thanks,
Patrick
thanks,
Patrick
Time to create page: 0.146 seconds
