chaotic_highlighting
28 Jan 2020 12:15 #156001
by nkp
chaotic_highlighting was created by nkp
Hi!
When the Gcode contains subroutines,
chaotic highlighting of the active line is observed.
(I"m using hal_sourceview.py )
The reason is clear - lcnc highlights the line number from the "main" code ,
when a subroutine is found - jumps to the line (line number) from the subroutine.
Is there any solution to this?
28 Jan 2020 13:55 #156008
Replied by cmorley on topic chaotic_highlighting
What version of linuxcnc?
I thought this problem was worked around already.
Chris
Chris
28 Jan 2020 14:13 - 28 Jan 2020 14:14 #156010
by nkp
Replied by nkp on topic chaotic_highlighting
lcnc 2.7.14
but userscreen
gtk
hal_sourceview.py
but userscreen
gtk
hal_sourceview.py
Last edit: 28 Jan 2020 14:14 by nkp.
28 Jan 2020 14:31 - 28 Jan 2020 14:31 #156012
There is comments in the code of hal_glib about subroutine line changes.
sourceview uses the line-changed and file-loaded signals.
It's not clear to me if it was thought to be fixed - maybe was just improved...
I would make a bug report.
Chris
Chris
Last edit: 28 Jan 2020 14:31 by cmorley.
10 Feb 2020 07:51 #156939
by nkp
github.com/LinuxCNC/linuxcnc/issues/681I would make a bug report.
10 Feb 2020 13:10 - 10 Feb 2020 14:23 #156947
by nkp
del
Last edit: 10 Feb 2020 14:23 by nkp.
10 Feb 2020 15:31 - 10 Feb 2020 15:32 #156961
I would think call level would be more likely.
maybe:
Chris
maybe:
if self.stat.call_level == 0:
self.old['line'] = self.stat.motion_line
Chris
Last edit: 10 Feb 2020 15:32 by cmorley.
10 Feb 2020 15:59 - 10 Feb 2020 16:03 #156964
by nkp
I tried to dothat would not jump UP
but it doesn't work (although it should seem to work))
line_old = old.get('line', None)
line_new = self.old['line']
if line_new > line_old:
self.emit('line-changed', line_new)
Last edit: 10 Feb 2020 16:03 by nkp.
10 Feb 2020 16:05 - 10 Feb 2020 16:06 #156966
by nkp
for nowhal_sourceview.py
def set_line_number(self,linenum):
self.offset = linenum
self.check_offset()
self.highlight_line(self.gstat, self.offset)
if linenum == 0: #nkp
self.line_mem = 0
def highlight_line(self, w, l):
if l > self.line_mem : #nkp
self.line_mem = l
else:
return
Last edit: 10 Feb 2020 16:06 by nkp.
11 Feb 2020 08:32 - 11 Feb 2020 08:33 #157027
by nkp
Axis
Of course, this is not a solution to the problem ...
but the line jumps a little less =)
--- /home/nkp//axis
+++ /home/nkp/linuxcnc/configs/jog/axis
@@ -664,7 +664,8 @@
self.notifications_clear = False
self.notifications_clear_info = False
self.notifications_clear_error = False
+ self.current_line_mem = 0
def start(self):
if self.running.get(): return
if not os.path.exists(linuxcnc.nmlfile):
@@ -734,14 +735,16 @@
root_window.tk.eval(pane_top + ".tabs raise manual")
if (self.current_task_mode == linuxcnc.MODE_MDI):
root_window.tk.eval(pane_top + ".tabs raise mdi")
- if (self.current_task_mode == linuxcnc.MODE_AUTO):
+ if (self.current_task_mode != linuxcnc.MODE_AUTO):
# not sure if anything needs to be done for this
pass
self.after = self.win.after(update_ms, self.update)
- self.win.set_current_line(self.stat.id or self.stat.motion_line)
+ if (self.stat.id or self.stat.motion_line) > self.current_line_mem :
+ self.win.set_current_line(self.stat.id or self.stat.motion_line)
+ self.current_line_mem = (self.stat.id or self.stat.motion_line)
speed = self.stat.current_vel
limits = soft_limits()
Last edit: 11 Feb 2020 08:33 by nkp.
Time to create page: 0.082 seconds
