How to modify, and use Hal_ LED color
10 Aug 2021 05:50 #217377
Replied by cmorley on topic How to modify, and use Hal_ LED color
ok good - glad I could help a bit.
26 May 2022 01:02 #243864
by yi2580
Replied by yi2580 on topic How to modify, and use Hal_ LED color
也许您理解错了我的意思,我的意思是在软件的界面中改变颜色
- powellscandrett
04 Jul 2022 15:03 - 11 Jul 2022 20:25 #246581
by powellscandrett
Replied by powellscandrett on topic How to modify, and use Hal_ LED color
I think you can do this without writing code. That is, you can find software that's convenient for this. It seems that now you know what to use without coding. As far as I know, there are detailed descriptions of switching modes, colours, brightness, and so on in the instructions for light bulbs from different manufacturers. For example, I moved my
car lighting
bulbs to a modem. Before that, I couldn't even imagine such an idea would work. In the instruction, I read where I can use it. Would you believe that these LEDs work perfectly in a modem? Anyway, I don't know how the code will change when using LEDs from different manufacturers. I always thought that the main thing in the code is your code, not the name of the device you want to upgrade.
Last edit: 11 Jul 2022 20:25 by powellscandrett.
Time to create page: 0.262 seconds
