installing GladeVCP toolchain on Rasberry PI from Image
25 Oct 2021 14:10 #224265
by geo01005
installing GladeVCP toolchain on Rasberry PI from Image was created by geo01005
I have installed LinuxCNC from the "LinuxCNC 2.8.1 Raspberry Pi OS based on Debian 10 Buster" image from the linuxcnc download section. I have my CNC machine all setup and working, but I'm working on adding functionality. I would like to use gladeVCP to do this.
Following the advice of I've found on the forum I've attempted to add the right version of gladeVCP to the install. This is what I've done so far:
sudo apt-get update
sudo apt-get install glade-3
sudo apt-get install linuxcnc-uspace-dev
This installed, what I believe is the correct version of glade (3.8.6)
However, none of the HAL widgets are available.
when I open glade from the command line using "glade-3" from the command line this is a portion the error message I get:
From my perspective adding a gladeVCP panel to my machine is more of a "configuration" activity of Linuxcnc rather than a development activity. I think that I understand that the setup will be a bit different that doing this with a run in place build. I don't really want to do this with a run in place build because I perceive that there is some reliability associated with using the release version of Linuxcnc without me introducing errors.
I'm not sure what I've done incorrectly, I suppose it is likely that I don't have the right PATH setup for the HAL components to be found correctly, but I'm not sure how to check, or what to modify. Some pointers would be appreciated. Thanks ahead of time.
sudo apt-get update
pi@linuxcnc:/usr/share/glade3 $ glade-3
File "<string>", line 1, in <module>
ImportError: No module named gladevcp
(glade-3:16395): GladeUI-WARNING **: 08:01:12.731: We could not find the symbol "h_al__hide_table_get_type"
(glade-3:16395): GladeUI-WARNING **: 08:01:12.732: Could not get the type from "HAL_HideTable"
(glade-3:16395): GladeUI-WARNING **: 08:01:12.732: Failed to load the GType for 'HAL_HideTable'
27 Oct 2021 12:49 #224504
Replied by andypugh on topic installing GladeVCP toolchain on Rasberry PI from Image
For Buster-amd64 we supply a package called glade-gtk2 but that is glade-3 version 3.8.6 so I think that you probably do have the right version.
Can you run the GladeVCP samples?
If so, a workaround might be to develop on an x86 PC and then run on the Pi. But I accept that isn't an elegant answer.
05 Nov 2021 04:54 - 06 Nov 2021 17:33 #225354
by geo01005
Replied by geo01005 on topic installing GladeVCP toolchain on Rasberry PI from Image
I went ahead and installed linuxcnc on a virtual machine on my x86 windows box. Thanks!
Last edit: 06 Nov 2021 17:33 by geo01005.
Time to create page: 0.124 seconds
