Error after installing Glade 3.22 and trying to revert back to Glade 3.8
- kimdanielarthur
15 Jan 2022 22:11 #231944
by kimdanielarthur
Error after installing Glade 3.22 and trying to revert back to Glade 3.8 was created by kimdanielarthur
I was in the process of installing Glade and did a 'Sudo apt-get install glade' which installed Glade 3.22. Realising that this is not compatible with linuxcnc2.8.2 i did 'sudo apt-get remove glade' and then 'sudo apt-get install glade-3'.
Glade itself works fine, however opening any glade components in linuxcnc or trying to include the gladevcp widgets in the glade editor fails with the following related to the python2.7 gladevpc libraries
"ImportError: When using gi.repository you must not import static modules like "gobject". Please change all occurrences of "import gobject" to "from gi.repository import GObject". See: bugzilla.gnome.org/show_bug.cgi?id=709183 "
Is this possible to fix without doing a full clean? Or some workaround? Maybe there is residue of the Glade 3.22 still confusing the system?
Let me know if any more info is needed!
Thanks,
Kim
Thanks,
Kim
- kimdanielarthur
15 Jan 2022 22:42 #231950
by kimdanielarthur
Replied by kimdanielarthur on topic Error after installing Glade 3.22 and trying to revert back to Glade 3.8
Full error message
File "<string>", line 1, in <module>
File "/usr/lib/python2.7/dist-packages/gladevcp/__init__.py", line 1, in <module>
from .hal_pythonplugin import *
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py", line 1, in <module>
from .hal_widgets import HAL_HideTable
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_widgets.py", line 16, in <module>
from gi.repository import gi
File "/usr/lib/python2.7/dist-packages/gi/__init__.py", line 39, in <module>
raise ImportError(_static_binding_error)
- kimdanielarthur
15 Jan 2022 23:08 #231964
by kimdanielarthur
I did
sudo apt-get remove python-gi
Which in term removed linuxcnc-uspace
So after
sudo apt-get install linuxcnc-uspace
it seems to all be back to working order
So after
Time to create page: 0.126 seconds
