- User Interfaces
- GladeVCP
- gladevcp command for testing error mmap tool data not available, continuing
16 Jan 2023 11:40 #262116
by JetForMe
I've managed to get a reasonable 2.9/master build running and I'm able to use Glade 3/GTK+3 to work on VCPs. The docs said I could test my panel by executing gladevcp on the command line, and that does display my panel and widgets, but also has an error that I'm not sure how to interpret or correct. Since it refers to tool data, something my panel will be manipulating, I wanted to make sure I dealt with it:
$ gladevcp -u mypanel.py mypanel.ui
[GladeVCP][INFO] Logging to: /home/rmann/gladevcp.log (logger.py:107)
tool_mmap_user(): file open fail: No such file or directory
tool_mmap_user(): no mmap file,continuing
mmap tool data not available, continuing emc/usr_intf/axis/extensions/emcmodule.cc
17 Jan 2023 01:52 #262204
Replied by cmorley on topic gladevcp command for testing error mmap tool data not available, continuing
Not an error. You can ignore it.
It's got to do with trying to connect to a tool database.
17 Jan 2023 02:30 - 17 Jan 2023 02:43 #262208
by JetForMe
Replied by JetForMe on topic gladevcp command for testing error mmap tool data not available, continuing
Please tell me more. All of this work I'm doing is around tool libraries, so I'm very curious to learn about these tool databases.
Last edit: 17 Jan 2023 02:43 by JetForMe.
17 Jan 2023 03:03 #262210
by JetForMe
Oh that’s great! Alas, the demo seems to have some issues:
/tmp/db_ran-file gets created, and I can run the tool directly:
But I can't load any tools in Axis. Tool file contents:
703 18:59: db_demo/ (2.9) $ linuxcnc db_ran.ini
LINUXCNC - 2.9.0~pre1
Machine configuration directory is '/home/rmann/linuxcnc/configs/sim/axis/db_demo'
Machine configuration file is 'db_ran.ini.expanded'
Starting LinuxCNC...
====Waiting for v2.1 version reply from ./db_ran.py
execv fail: Bad address
!!!!!db_init: fork FAIL
FORK: Bad address
1080309 IO::tooldata_db_init() FAIL
tooldata_load: Failed to load tooldata from database
!!!! db_version MISMATCH require:v2.1 received:emc/iotask/ioControl.cc 786:
1080308 IO::tooldata_db_init() FAIL
emc/iotask/ioControl.cc 786: can't load tool table.
Note: Using POSIX non-realtime
Found file(LIB): /home/rmann/linuxcnc/lib/hallib/basic_sim.tcl
setup_kins: cmd=loadrt trivkins coordinates=XYZABCUVW
780 18:55: db_demo/ (2.9) $ ./db.py
./db.py: starting(random_toolchanger) n_pockets = 15
./db.py: init_tools(): tfirst=10 tlast=19
v2.1
./db.py:
NOTE: Terminal command to monitor database file:
$ watch -c -n 1 cat /tmp/db_ran_file
./db.py: **Start: tool_modify_task
./db.py: **Active threads:['tool_modify_task']
./db.py: **Begin tool_modify_task tno=15 letter=A ct_max=2 wait_secs=5
./db.py: tool_modify_task: tno=15 A=0.100
./db.py: tool_modify_task: tno=15 A=0.101
./db.py: **End tool_modify_task ct=2
./db.py: **Start: tool_update_task
./db.py: **Active threads:['tool_update_task']
./db.py: **Begin tool_update_task begin_tno=40 ct_max=2 wait_secs=5
./db.py: add_dbtool: ADD tno=40 pno=120
./db.py: add_dbtool: ADD tno=41 pno=121
./db.py: **End tool_update_task ct=2
Every 1.0s: cat /tmp/db_ran_file debian: Mon Jan 16 19:03:19 2023
T0 P0
T10 P110 D0.10 Z0.10
T11 P111 D0.10 Z0.11
T12 P112 D0.10 Z0.12
T13 P113 D0.13 Z0.13
T14 P114 D0.14 Z0.14
T15 P115 D0.15 Z0.15 A0.101
T16 P116 D0.16 Z0.16
T17 P117 D0.17 Z0.17
T18 P118 D0.18 Z0.18
T19 P119 D0.19 Z0.19
T40 P120 D0.04 Z0.4
T41 P121 D0.041 Z0.41
; Recent (last 10) db history:
; Created /tmp/db_ran_file (init_tools)
; tno: 15 modified param A=0.100
; tno: 15 modified param A=0.101
; tno: 40 added (add_dbtool)
; tno: 41 added (add_dbtool)
17 Jan 2023 11:22 #262226
Replied by rodw on topic gladevcp command for testing error mmap tool data not available, continuing
Not sure of your environment but both the sims worked for me. I have no need for it but expected it to work cos I think it ws written by Dewey Garrett who is very precise with his work,,
18 Jan 2023 00:05 #262290
by phillc54
Replied by phillc54 on topic gladevcp command for testing error mmap tool data not available, continuing
I had the same problem on an arm64 rip build but I noticed that Dewey pushed a change and that has fixed it for me.
github.com/LinuxCNC/linuxcnc/commit/f20a...d89a67faf1a5a45174ef
18 Jan 2023 01:12 #262297
I am in awe of his work!
See, I told you he was precise! Precisely on time!I had the same problem on an arm64 rip build but I noticed that Dewey pushed a change and that has fixed it for me.
18 Jan 2023 01:22 #262298
by JetForMe
And that seems to have fixed things!
- User Interfaces
- GladeVCP
Time to create page: 0.212 seconds
