GladeVCP and venv?
28 Jan 2023 11:38 - 28 Jan 2023 11:40 #263072
by JetForMe
GladeVCP and venv? was created by JetForMe
I've been working on my VCP outside of GladeVCP/LinuxCNC by creating a little scaffold.py GTK app to display my UI (I don't yet interface with the HAL so this was easy). I'm able to run in debug mode in VS Code and it speeds development.
Now I'm trying to integrate into my VCP (instead of launching scaffold.py), and I'm having some trouble getting gladevcp (or linuxcnc, for that matter) to respect my venv when they launch, which means it can't find my dependencies that I'm developing in conjunction with the VCP.
With my venv activated, I did
which put a mymodule.egg-link file in the venv site-packages directory pointing to the local mymodule directory in my home dir.
Any idea what I can do to make this work?
pip install -e ~/mymodule
Last edit: 28 Jan 2023 11:40 by JetForMe.
28 Jan 2023 20:45 #263119
by JetForMe
Replied by JetForMe on topic GladeVCP and venv?
I've used `update-alternatives` to make python3.11 the system-wide python, but gladevcp still launches python3.9. How is gladevcp finding python?
28 Jan 2023 21:27 - 28 Jan 2023 21:27 #263121
by JetForMe
Ah! Linux filesystems are case-dependent, but macOS is (usually) not. So my import API statement was failing to find api.py when on Linux.
Still want to figure out how to run linuxcnc/gladevcp with a different python, though.
Last edit: 28 Jan 2023 21:27 by JetForMe.
Time to create page: 0.180 seconds
