gladeVCP timer error
23 Jan 2024 19:56 #291459
Replied by Aciera on topic gladeVCP timer error
yes, but what about the hal_label widget?
23 Jan 2024 20:34 #291461
by tommy
Replied by tommy on topic gladeVCP timer error
For example I tried to connect pin totalofseconds to seconds hal_label which was working with seconds pin, and it also triggered "type mismatch" after change.
I also checked in HAL Configuration for both pins, seconds and totalofseconds and they are counting as expected (whole integer number / type u32).
24 Jan 2024 07:56 #291501
What does the the ' hal configuration' tool show for 'pin type' when you select the gladevcp hal_label pins, for example 'gladevcp.hal_label5'?
24 Jan 2024 19:19 #291546
by tommy
Time to create page: 0.130 seconds
