ignore limit switch do not work
11 Aug 2011 14:11 #12416
by wbeppler
Elektronik u. Softwareentwicklung
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
DE-78355 Hohenfels-Kalkofen
This email address is being protected from spambots. You need JavaScript enabled to view it.
ignore limit switch do not work was created by wbeppler
hello,
if my machine moves to a limit-switch i can not drive free by "ignore limits".
i only connected my pos and neg switch to only one input and i did try
net z-pos-limit hm2_5i20.0.gpio.061.in
and i changed to
net z-neg-limit hm2_5i20.0.gpio.061.in
both time same problem.
my 1st question:
if i'm on pos-limit, i only can travel to neg-direction ?
my 2nd question:
is it necessary to cut the hardware-wire of the switch to free my axis ?
is the "ignore limits"-button (i hope i write it correct because in german the is a "Grenzwerte aufheben") connected to a output where i have to connect a relais to cut the limit-signal ?
how to manage this problems ?
thanks
wolfgang
and i changed to
my 1st question:
my 2nd question:
thanks
wolfgang
Wolftec GmbH
Wolfgang Beppler
Kratellen 23
11 Aug 2011 14:27 #12418
by BigJohnT
Replied by BigJohnT on topic Re:ignore limit switch do not work
If your limits are shared program something like this
net both-home-x <= parport.0.pin-10-in-not
net both-home-x => axis.0.home-sw-in
net both-home-x => axis.0.neg-lim-sw-in
net both-home-x => axis.0.pos-lim-sw-in
This way EMC knows you have only one switch and will allow you to jog in any direction to get off of the switch.
2 No.
2 No.
Time to create page: 0.092 seconds
