axis has fliped
12 Nov 2011 11:28 #14781
by guyver001
axis has fliped was created by guyver001
Hi guys bit of a silly one fired up my mill yesterday and found that the y axis has fliped i know it can be changed in stepconfig program
but i i would like to know how to do it manualy need to reverse the y axis
thanks
thanks
12 Nov 2011 12:48 #14783
by Rick G
Replied by Rick G on topic Re:axis has fliped
You can edit your .ini file and change the SCALE for the axis that is backward.
If the number is positive say 5000
change it to -5000
SCALE= 5000
to
SCALE= -5000
If it is a stepper system you could also reverse just on set of wires to the motor.
You could also invert the parallel port pin for direction for that axis.
Rick G
change it to -5000
SCALE= 5000
to
SCALE= -5000
Rick G
12 Nov 2011 13:01 #14784
by guyver001
Replied by guyver001 on topic Re:axis has fliped
that worked thanks Rick i knew it would be some thing simple lol
Time to create page: 0.126 seconds
